Page 1 of 1
Installing iPhone 4 Verizon Display Assembly
This guide has more recent changes. Switch to the latest unverified version.
Replace a cracked front panel or a broken display on your Verizon iPhone 4.
- Author: Andrew Bookholt
- Difficulty: Difficult
Use this guide to replace a cracked front panel or a broken LCD.
After successfully replacing the display assembly, protect your new display from scratches by installing a screen protector.
Sections
- Rear Panel 3 steps
- Battery 3 steps
- Dock Connector Cable 5 steps
- Rear Camera 3 steps
- Logic Board 8 steps
- Vibrator 1 step
- Display Assembly 11 steps
Tools
Tools (continued)
Relevant parts
- View:
- Paginated
- Full width
Edit
Step 1
Rear Panel
Before disassembling your iPhone, be sure it is powered off.
Remove the two 3.6 mm Pentalobe screws next to the dock connector.
During reassembly, we recommend you replace the 5-point screws with equivalent Phillips screws. Our Liberation Kit provides the tools and screws needed to replace the Pentalobe screws with Phillips screws.
The 5-Point Screwdriver should only be used once, as it has the potential to strip the screws.
Edit
Step 14
Use the edge of a plastic opening tool to pry the rear camera connector up from its socket on the logic board.
Be careful not to break any components off the surrounding area on the logic board as you pry upwards.
Remove the rear camera from the iPhone.
Be careful not to scratch the back of the display assembly after the removal of the rear facing camera.
Edit
Step 15
Logic Board
Remove the five cables near the top of the logic board in the following order:
Headphone jack/volume button cable
Power button cable
Front facing camera cable
Digitizer cable
Display data cable
To disconnect the cables, use the edge of a plastic opening tool to gently lift their connectors up and out of the sockets on the logic board.
Be careful not to break any of the small and delicate surface mount components as you disconnect the cables.
Edit
Step 21
Carefully lift the logic board from the end closest to the speaker enclosure and slide it away from the top edge of the iPhone.
Remove the logic board.
Before reassembly, be sure to clean all metal-to-metal contact points on the logic board (not the mating halves of connectors) with a de-greaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to cause grounding issues.
Edit
Step 26
Remove the speaker enclosure assembly from the iPhone.
Before reinstalling the speaker enclosure assembly's screws, be sure the Wi-Fi grounding fingers are installed below the lip in the iPhone's metal case as seen in the second picture.
Before reassembly, be sure to clean all metal-to-metal contact points between the grounding fingers of the Wi-Fi antenna and the case of the iPhone with a de-greaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to cause wireless interference issues.
Edit
Step 32
Loosen the three large-headed Phillips screws along the volume button side of the iPhone about one half turn.
It is not necessary to completely remove these screws. When reinstalling the display assembly, be sure the washers are closest to the screw head (as seen in the second picture).
Edit
Step 34
Use the edge of a plastic opening tool to gently pry up the display assembly around its perimeter.
Remove the display assembly from the iPhone.
When reinstalling the display assembly, be sure the digitizer and display data cables are completely pulled through the slot cut into the outer case before pressing the display assembly down into the outer case. Failure to do so will cause the digitizer cable to not reach its socket on the logic board.
After reassembly, protect your new display from any scratches by installing a new screen protector.
This guide has been completed 78 times.
Page 1 of 1
