Installing iPhone 4 Front Glass Display Assembly
Prerequisite Only
Prerequisite Only
Please note that this guide is only a prerequisite for other guides.
Replace the display assembly in your iPhone 4.
  • Author: Walter Galan
  • Time required: One Hour
  • Difficulty: Difficult
  • Add Note x
  • x 936
Use this guide to replace your iPhone's display assembly. Replacing the display assembly will give you a new front glass panel, digitizer, and LCD. The LCD is adhered to the glass at the factory and the two parts are not separable without damage.
After successfully replacing the display assembly, protect your new display from scratches by installing a screen protector.
Image #1 Image #2
Add Note Edit Step 1 — Rear Panel  ¶
  • Your iPhone 4 rear cover may have either two #000 Phillips screws or Apple's 5-Point "Pentalobe" screws (second image). Check which screws you have, and ensure you also have the correct screwdriver in order to remove them.
  • Remove the two 3.6 mm Pentalobe or Phillips #000 screws next to the dock connector.
  • During reassembly, we recommend you replace the 5-point screws with equivalent Phillips screws. Our Liberation Kit provides the tools and screws needed to replace the Pentalobe screws with Phillips screws.
Image #1 Image #2
Add Note Edit Step 2  ¶
  • Push the rear panel toward the top edge of the iPhone.
  • The panel will move about 2 mm.
Image #1
Add Note Edit Step 3  ¶
  • Pinch the rear panel with your fingers and lift it away from the iPhone.
Image #1 Image #2
Add Note Edit Step 4 — Battery  ¶
  • Remove the single 2.5 mm Phillips screw securing the battery connector to the logic board.
    • Some devices may have two screws, one of which holds down the contact pad which is located above the screw indicated in red in the photo.
  • Use a plastic opening tool to gently disconnect the battery connector from its socket.
Image #1 Image #2 Image #3
Add Note Edit Step 5  ¶
  • Use the clear plastic pull tab to gently lift the battery out of the iPhone.
  • Be careful when removing the battery with the plastic pull tab. On some units, Apple uses an excessive amount of glue, making it virtually impossible to remove the battery in this fashion (with the tab possibly tearing due to excessive force).
  • For batteries that "stick", you could use the iPod opening tool to assist (take extra care whilst doing so).
  • You might find it easier to pry the battery out from the right-hand side because no glue is used on this side.
  • Remove the battery.
  • Before reconnecting the battery connector, be sure the pressure contact (shown in red) is properly positioned next to the battery connector.
  • Before reassembly, be sure to clean all metal-to-metal contact points on the pressure contact as well as its contact point on the rear panel with a de-greaser such as Windex (96% ethanol alcohol works well too, but make sure that contacts are dry when done). The oils on your fingers have the potential to cause wireless interference issues.
Image #1 Image #2
Add Note Edit Step 6 — Logic Board  ¶
  • Use a SIM card eject tool or a paperclip to eject the SIM card and its holder.
  • This may require a significant amount of force.
  • Remove the SIM card and its holder.
Image #1 Image #2
Add Note Edit Step 7  ¶
  • Remove the following two screws:
    • One 1.2 mm Phillips
    • One 1.6 mm Phillips
  • Remove the thin steel dock connector cable cover from the iPhone.
  • Before reassembly, be sure to clean all metal-to-metal contact points on the dock connector cable cover with a de-greaser such as windex. The oils on your fingers have the potential to cause wireless interference issues.
Image #1 Image #2
Add Note Edit Step 8  ¶
  • Use an iPod opening tool to gently pry the dock cable connector up off the logic board from both short ends of the connector.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Flathead 3/32" or 2.5 mm Screwdriver
Plastic Opening Tools
Phillips #000 Screwdriver
$9.95 · 50+ In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 7 In stock
Inspection Scope
$39.95 · 37 In stock
Frictionless Ratchet
$24.95 · 47 In stock
Portable Anti-Static Mat
$24.95 · 15 In stock
Popular Device Products
iPhone 4 Replacement Battery
$24.95 · 50+ In stock
iPhone 4 Display Assembly (GSM/AT&T)
$94.95 · 50+ In stock
iPhone 4 Home Button Assembly
$14.95 · 50+ In stock
iPhone 4/4S Liberation Kit
