Installing iMac G3 Model M4984 Hard Drive
User-Contributed Guide
This guide is not managed by iFixit staff.
  • Author: Chris Green
  • Time required: 10 - 20 Minutes
  • Difficulty: Moderate
  • Add Note x
  • x 8
The iMac G3 Uses a 3.5" IDE Hard Drive. It supports data partitions no larger then 128GB and boot partitions no larger then 8GB (The 8GB limit only applies to iMac G3 tray loaders).
Sections
first image
Add Note Edit Step 1 — Logic Board  ¶
  • The iMac G3. This was a great computer for the time, and had plenty of features.
first image
Add Note Edit Step 2  ¶
  • Start by flipping the iMac upside-down. It may help to lay it on a towel, so you don't damage the screen, or scratch the face.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 3  ¶
  • Remove this Phillips screw.
  • Using a flathead screwdriver, work your way around the bottom cover, until it comes off.
  • Then, lift the bottom cover up and out, and set it aside.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 4  ¶
  • Now, remove the DB-15 Video connector from the logic board.
  • It may be helpful to use a Phillips screwdriver to remove the thumbscrews.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 5  ¶
  • Remove the power cable from the logic board assembly.
first image
thumb image 1
thumb image 2
Add Note Edit Step 6  ¶
  • Remove the front panel connector.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 7  ¶
  • Now, remove these Phillips screws.
  • Now, grab the logic board assembly by the piece of plastic, and lift it out.
first image
Add Note Edit Step 8  ¶
  • The logic board assembly. This is the heart of the computer, it contains the motherboard, CPU, RAM, V-RAM, PRAM battery, the hard drive, and the optical drive.
first image
Add Note Edit Step 9 — Optical Drive  ¶
  • Now to remove the optical drive!
first image
Add Note Edit Step 10  ¶
  • The optical drive is located near the front of the assembly.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 11  ¶
  • To remove the drive, push it in, lift up, and then pull forward.
  • As you pull the drive forward, disconnect the ribbon cable and set it aside.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 12  ¶
  • Remove the two phillips #00 screws.
  • Then remove the board. This will reveal that it is a standard PATA drive.
  • Congrats, the drive is free! You can use any PATA-tray loading drive in the iMac G3 which means you can install a CDRW to burn CDs in OS9 or X(if using OSX,install that DVD writer) but, of course only original drives will match the great look of the iMac).
first image
Add Note Edit Step 13 — Hard Drive  ¶
  • Hard Drive Removal:
first image
thumb image 1
thumb image 2
Add Note Edit Step 14  ¶
  • Start by removing these Phillips screws:
  • Now, remove all of these cables:
first image
thumb image 1
thumb image 2
Add Note Edit Step 15  ¶
  • Now, remove the optical drive retention spring.
  • Push in on both sides, and pull towards you releasing the retention spring.
  • It may help to do it one side at a time.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 16  ¶
  • Now lift the drive up, and pull it out.
  • Make sure that no cables are snagged before completed pulling out the drive!
first image
Add Note Edit Step 17  ¶
  • When installing a new drive, make sure that the drive jumper block is set to "Single drive". In most drives, this means removing the jumper, or positioning the jumper horizontally instead of vertically, so you don't lose it.
  • To remove the drive from the metal caddy, remove these four screws from the side of the drive.
For more information, check out the iMac G3 Model M4984 device page.
Did you successfully follow this guide?
This guide has been completed 8 times.
