Xbox 360 S Hard Drive Replacement
  1. Xbox 360 S Hard Drive Replacement, Hard Drive: step 1, image 1 of 3 Xbox 360 S Hard Drive Replacement, Hard Drive: step 1, image 2 of 3 Xbox 360 S Hard Drive Replacement, Hard Drive: step 1, image 3 of 3
    • Orient the Xbox 360 S so that the bottom of the console is facing toward you.
    • Push the latch holding down the hard drive cover to the left.
    • Pull the hard drive cover away from the console.
  2. Xbox 360 S Hard Drive Replacement: step 2, image 1 of 3 Xbox 360 S Hard Drive Replacement: step 2, image 2 of 3 Xbox 360 S Hard Drive Replacement: step 2, image 3 of 3
    • Firmly grasp the fabric tab labeled with the size of the hard drive (e.g. "250 GB") attached to the hard drive.
    • Pull the hard drive straight out of the console.
    • The fabric tab is attached to a catch further inside the hard drive housing. It will take some force to pull the hard drive out.
106 other people completed this guide.
Brett Hartt
131,241 Reputation
143 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,729 Guides authored
5 Guide Comments
do you have to transfer the OS? or data? if so what utility is used? do you need a data transfer cable?
Can I just add an external drive to supplement the existing HDD?
David Johnson - Reply
no the os is on the internal drive all the hard drive is doing is adding more storge space
Nightwolf Gamer -
My hardrive says its unformated but its not and i dont want to loose content
Javier Eduardo Pacheco Hazim - Reply
Can I take the external out of the little black cover?
Lallie Cooney - Reply
Will it play backwards compatible games
justin rzonca - Reply
Past 24 Hours: 17
Past 7 Days: 126
Past 30 Days: 569
All Time: 158,742
