Installing MacBook Pro 13" Unibody Early 2011 Optical Drive Replacement
Replace a broken optical drive in your Early 2011 MacBook Pro 13" Unibody.
  • Add Note x
  • x 11
Use this guide to replace a broken optical drive.
first image
Add Note Edit Step 1 — Lower Case  ¶
  • Remove the following ten screws:
    • Three 14.4 mm Phillips screws
    • Three 3.5 mm Phillips screws
    • Four 3.5 mm shouldered Phillips screws
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • Use your fingers to pry the lower case away from the body of the MacBook near the vent.
  • Remove the lower case.
first image
thumb image 1
thumb image 2
Add Note Edit Step 3 — Battery  ¶
  • Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
  • It is useful to pry upward on both short sides of the connector to "walk" it out of its socket.
first image
Add Note Edit Step 4  ¶
  • Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
first image
Add Note Edit Step 5 — Optical Drive  ¶
  • Use the flat end of a spudger to pry the AirPort/Bluetooth ribbon cable connector up from its socket on the logic board.
first image
Add Note Edit Step 6  ¶
  • Carefully pull the camera cable out of its socket on the logic board.
  • Pull the cable parallel to the face of the logic board. Pulling it upward may damage the logic board or the cable itself.
first image
thumb image 1
thumb image 2
Add Note Edit Step 7  ¶
  • Carefully move the AirPort/Bluetooth ribbon cable out of the way as you peel the camera cable off the adhesive securing it to the subwoofer and the AirPort/Bluetooth bracket.
  • De-route the camera cable out from under the retaining finger molded into the AirPort/Bluetooth bracket.
first image
thumb image 1
thumb image 2
Add Note Edit Step 8  ¶
  • Use the tip of a spudger to pry the antenna connector closest to the logic board up from its socket on the AirPort/Bluetooth board.
  • De-route the antenna cable from under the finger molded into the AirPort/Bluetooth bracket.
first image
Add Note Edit Step 9  ¶
  • Remove the following five screws:
    • Two 10.3 mm Phillips screws
    • Two 3.1 mm Phillips screws
    • One 5 mm Phillips screw
first image
thumb image 1
thumb image 2
Add Note Edit Step 10  ¶
  • Pull the AirPort/Bluetooth assembly and the Subwoofer upward near the center of the side of the optical drive until they clear each other.
  • Move the AirPort/Bluetooth assembly and the subwoofer away from the top of the optical drive.
first image
thumb image 1
thumb image 2
Add Note Edit Step 11  ¶
  • Pull the right speaker/subwoofer cable out from under the retaining finger near the side of the optical drive.
  • Pull the right speaker/subwoofer cable upward to disconnect it from the logic board.
first image
Add Note Edit Step 12  ¶
  • Use the flat end of a spudger to pry the hard drive cable connector up from its socket on the logic board.
  • Bend the hard drive cable away from the optical drive.
first image
Add Note Edit Step 13  ¶
  • Use the flat end of a spudger to pry the optical drive connector up from its socket on the logic board.
first image
Add Note Edit Step 14  ¶
  • Remove the three 2.7 mm Phillips screws securing the optical drive to the upper case.
first image
Add Note Edit Step 15  ¶
  • Pull the optical drive upward from its edge closest to the display and remove it from the upper case.
first image
thumb image 1
thumb image 2
Add Note Edit Step 16 — Optical Drive Replacement  ¶
  • Pull the optical drive cable away from the optical drive.
  • Be sure to pull on the connector, not the cable itself.
  • Optical drive remains.
For more information, check out the MacBook Pro 13" Unibody Early 2011 device page.
Did you successfully follow this guide?
This guide has been completed 11 times.
