Installing iPhone 5 Rear Case
Remove the entire rear case from your iPhone 5.
- Author: Andrew Goldberg
- Difficulty: Moderate
Use this guide to remove every component from the rear case of your iPhone 5.
Sections
- Front Panel Assembly 9 steps
- Battery 5 steps
- Logic Board Assembly 12 steps
- Lightning Connector and Speaker Assembly 3 steps
- Front Panel Clips 2 steps
- Rear Case 9 steps
Tools
- View:
- Single page
Edit
Step 3
Make sure the suction cup is firmly attached to the front panel assembly.
While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices.
With a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while you pull up with the suction cup.
There are several clips attaching the front panel assembly to the rear case, so you may need to use a combination of the suction cup and plastic opening tool to free the front panel assembly.
Edit
Step 5
Once the clips have been released on the bottom and sides of the front panel assembly, pull the bottom of the assembly away from the rear case.
Do not try to completely remove the front panel assembly from the rear case, as there are several ribbon cables still attached at the top of the iPhone.
Lift and rotate the front panel assembly up to about 90 degrees from the rear case.
Edit
Step 8
Use a plastic opening tool to disconnect the three front panel assembly cables:
Front-facing camera and sensor cable
Digitizer cable
LCD cable
When reassembling your phone, The LCD cable may pop off the connector. This can cause white lines to appear when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best was to power cycle your phone is to disconnect and reconnect the battery.
Page 1 of 5
