Installing Xbox 360 Red Ring of Death Fix Kit
Featured Guide
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Fix a red ringed (RROD) Xbox 360.
  • Add Note x
  • x 312
Use this guide to install iFixit's Red Ring of Death Fix Kit.
Reflowing the motherboard after completing Step 49 of this guide (before you install the RROD fix kit) both provides a higher chance of success in fixing red ring failures and also safeguards against future failures.
Sections (continued)
Tools
Relevant Parts
Image #1 Image #2
Add Note Edit Step 1 — Hard Drive  ¶
  • Grasp the hard drive assembly and press the release button while lifting its front edge.
  • Remove the hard drive assembly from the top vent.
Image #1
Add Note Edit Step 2 — Bottom Vent  ¶
  • Stand the console vertically with the bottom edge facing up.
  • Insert the flat end of a spudger or the edge of an Xbox 360 opening tool into the small gap at the front edge of the bottom vent.
  • Pry the front edge of the bottom vent away from the faceplate.
Image #1 Image #2 Image #3
Add Note Edit Step 3  ¶
  • In the next few steps, you will use the tip of a spudger or the finger of an Xbox 360 opening tool to release the clips along the left and right sides of the bottom vent. Their locations are highlighted in red.
  • You will insert the tool into the holes molded into the white plastic side case pieces.
Image #1 Image #2
Add Note Edit Step 4  ¶
  • To release the clips, work from the front edge of the bottom vent.
  • While slightly lifting the front edge of the bottom vent, use the tip of a spudger to push the clips closest to the front of the bottom vent towards the inside of the console.
Image #1 Image #2
Add Note Edit Step 5  ¶
  • Repeat the same process to release the two center clips on the bottom vent.
Image #1 Image #2
Add Note Edit Step 6  ¶
  • Use the tip of your spudger to release the clips on the bottom vent nearest the back of the Xbox.
Image #1
Add Note Edit Step 7  ¶
  • Remove the bottom vent from the 360.
Image #1 Image #2
Add Note Edit Step 8 — Faceplate  ¶
  • Insert the edge of a spudger between the faceplate and the outer casing near the power button.
  • Run your spudger along the edge of the faceplate to release the clips securing it to the front of the console.
  • You may also accomplish this task by using the edge of the Xbox 360 opening tool, but it may scratch the plastic case.
  • Alternatively, you can use your hands to carefully pull the faceplate away from the Xbox.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
Metal Spudger Set
$7.95 · 50+ In stock
Arctic Silver ArctiClean
$7.95 · 20 In stock
Related Products
$29.95 · 50+ In stock
