Installing MacBook Unibody Model A1342 Dual Hard Drive
Featured Guide
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Use this guide to install a second hard drive in place of the optical drive.
  • Add Note x
  • x 11
There are many benefits to adding a second hard drive to your laptop such as improved speeds, greater storage space, and less heartache when installing new software. Use this guide to install one using our optical bay hard drive enclosure.
Image #1
Add Note Edit Step 1 — Lower Case  ¶
  • Remove the eight 4 mm Phillips screws securing the lower case to the MacBook.
Image #1 Image #2 Image #3
Add Note Edit Step 2  ¶
  • The lower case is constructed of rubber-coated aluminum. Do not excessively bend the aluminum during removal, as any permanent deformation will cause tolerance issues after reassembly.
  • Slightly lift the lower case near the vent opening.
  • Continue running your fingers between the lower and upper cases until the upper case pops off its retaining clips.
  • The location of these three clips is shown in the third picture.
Image #1
Add Note Edit Step 3 — Battery  ¶
  • For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge. This step is optional and is not required.
  • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
  • It may be easier to use your fingernails to lift up on both sides of the connector.
Image #1
Add Note Edit Step 4 — Rear Vent  ¶
  • Remove the following screws from the optical drive side of the rear vent:
    • Two 10 mm T8 Torx
    • Two 5.2 mm Phillips
Image #1
Add Note Edit Step 5  ¶
  • Remove the following screws from the port side of rear vent:
    • Two 10 mm T8 Torx
Image #1
Add Note Edit Step 6  ¶
  • Carefully lift the rear vent out of the upper case.
Image #1
Add Note Edit Step 7 — Optical Drive  ¶
  • Remove the single 12 mm Phillips screw securing the top of the rear speaker housing to the upper case.
Image #1
Add Note Edit Step 8  ¶
  • Remove the single 2.2 mm Phillips screw inserted horizontally into the side of the optical drive.
Next » « Previous
Required Tools
T8 Torx Security Bit Screwdriver
$6.95 · 38 In stock
Spudger
$2.95 · 50+ In stock
T6 Torx Screwdriver
$4.95 · 7 In stock
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Related Products
750 GB 7200 RPM 2.5" Hard Drive
$109.95 · 16 In stock
Unibody Laptop Dual Drive
$39.95 · 3 In stock
Recommended Tools
Universal Drive Adapter
$29.95 · 50+ In stock
Inspection Scope
$39.95 · 17 In stock
Portable Anti-Static Mat
$24.95 · 10 In stock
