Installing MacBook Pro 15" Retina Display Mid 2012 SSD
Featured Guide
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Replace the SSD in your MacBook Pro 15" Retina Display Mid 2012.
  • Add Note x
  • x 8
Time for a storage upgrade? Possibly your SSD has become tired in its old age? Use this guide to replace the SSD.
Image #1
Add Note Edit Step 1 — Lower Case  ¶
  • Remove the following pentalobe screws securing the lower case to the MacBook Pro with Retina display.
    • Eight 3.0 mm
    • Two 2.3 mm
Image #1
Add Note Edit Step 2  ¶
  • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
  • Set the lower case aside.
Image #1
Add Note Edit Step 3 — Battery Connector  ¶
  • Peel back the warning label covering the battery connector.
Image #1 Image #2
Add Note Edit Step 4  ¶
  • Using the flat end of a spudger, gently pry the battery connector straight up out of its socket on the logic board.
  • Bend the battery cables back and out of the way, ensuring that the battery connector doesn't accidentally make contact with the logic board.
Image #1
Add Note Edit Step 5 — SSD  ¶
  • Remove the single 3.1 mm T5 Torx screw securing the SSD to the logic board.
Image #1
Add Note Edit Step 6  ¶
  • Slightly lift the leftmost side of the SSD and firmly slide it straight away out of its socket on the logic board.
Required Tools
Spudger
$2.95 · 50+ In stock
T5 Torx Screwdriver
$6.95 · 50+ In stock
Related Products
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 26 In stock
Inspection Scope
$39.95 · 39 In stock
Frictionless Ratchet
$24.95 · 48 In stock
Portable Anti-Static Mat
$24.95 · 18 In stock
