Installing MacBook Pro 15" Retina Display Mid 2012 AirPort Board
Replace the AirPort Board in your MacBook Pro 15" Retina Display Mid 2012.
  • Add Note x
  • x 7
Having connectivity issues? Use this guide to replace the AirPort board.
Image #1
Add Note Edit Step 1 — Lower Case  ¶
  • Remove the following pentalobe screws securing the lower case to the MacBook Pro with Retina display.
    • Eight 3.0 mm
    • Two 2.3 mm
Image #1
Add Note Edit Step 2  ¶
  • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
  • Set the lower case aside.
Image #1
Add Note Edit Step 3 — Battery Connector  ¶
  • Peel back the warning label covering the battery connector.
Image #1 Image #2
Add Note Edit Step 4  ¶
  • Using the flat end of a spudger, gently pry the battery connector straight up out of its socket on the logic board.
  • Bend the battery cables back and out of the way, ensuring that the battery connector doesn't accidentally make contact with the logic board.
Image #1
Add Note Edit Step 5 — AirPort Board  ¶
  • Use the tip of a spudger to detach the three antenna connectors up from their sockets on the AirPort board.
Image #1 Image #2
Add Note Edit Step 6  ¶
  • Remove the single 2.9 mm T5 Torx screw securing the AirPort board to the logic board.
  • Grasp the edges of the board and slide it out from its connector.
  • Lift and remove the AirPort board.
Required Tools
Spudger
$2.95 · 50+ In stock
T5 Torx Screwdriver
$6.95 · 50+ In stock
Related Products
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 27 In stock
Inspection Scope
$39.95 · 40 In stock
Frictionless Ratchet
$24.95 · 49 In stock
Portable Anti-Static Mat
$24.95 · 19 In stock
