Installing MacBook Pro 13" Unibody Mid 2012 Battery
Featured Guide
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Replace the battery in your Late 2011 MacBook Pro 13" Unibody.
  • Add Note x
  • x 7
Use this guide to replace a worn-out battery.
Image #1
Add Note Edit Step 1 — Lower Case  ¶
  • Remove the following ten screws:
    • Three 14.4 mm Phillips #00 screws
    • Three 3.5 mm Phillips #00 screws
    • Four 3.5 mm shouldered Phillips #00 screws
Image #1 Image #2
Add Note Edit Step 2  ¶
  • Use your fingers to pry the lower case away from the body of the MacBook near the vent.
  • Remove the lower case.
Image #1 Image #2
Add Note Edit Step 3 — Battery Connection  ¶
  • Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
  • It is useful to pry upward on both short sides of the connector to "walk" it out of its socket. Be careful with the corners of the connectors, they can be easily broken off.
Image #1
Add Note Edit Step 4  ¶
  • Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
Image #1
Add Note Edit Step 5 — Battery Replacement  ¶
  • Remove the following two screws:
    • One 5.6 mm Tri-wing screw
    • One 13 mm Tri-wing screw
Image #1
Add Note Edit Step 6  ¶
  • Carefully peel the battery warning label off the upper case between the battery and the optical drive.
  • Do not remove the label from the battery.
Image #1
Add Note Edit Step 7  ¶
  • Use the attached plastic pull tab to remove the battery from the upper case.
Required Tools
Spudger
$2.95 · 50+ In stock
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Tri-wing Y1 Screwdriver
$9.95 · 50+ In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 9 In stock
Inspection Scope
$39.95 · 37 In stock
Frictionless Ratchet
$24.95 · 47 In stock
Portable Anti-Static Mat
$24.95 · 15 In stock
Popular Device Products
