Installing MacBook Air 11" Mid 2011 Trackpad
Installing the Trackpad in the mid 2011 MacBook Air 11".
  • Add Note x
  • x 3
Navigating through your computer using the TAB key is not fun. Replace a broken trackpad using this guide.
Image #1
Add Note Edit Step 1 — Lower Case  ¶
  • Before proceeding, shut down and close your computer. Lay it on a soft surface top-side down.
  • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
  • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
Image #1
Add Note Edit Step 2  ¶
  • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
Image #1 Image #2
Add Note Edit Step 3 — Battery  ¶
  • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
  • Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
Image #1
Add Note Edit Step 4  ¶
  • Remove the following five screws securing the battery to the upper case:
    • Two 5.2 mm T5 Torx screws
    • One 6 mm T5 Torx screw
    • Two 2.6 mm T5 Torx screws
Image #1
Add Note Edit Step 5  ¶
  • When handling the battery, avoid squeezing or touching the six exposed lithium polymer cells.
  • Lift the battery from its edge nearest the logic board and remove it from the upper case.
Image #1 Image #2
Add Note Edit Step 6 — Trackpad  ¶
  • Use the point of a spudger to lift the ZIF connector retaining flap on the trackpad data cable.
  • Gently slide the ribbon cable out of the ZIF connector.
Image #1 Image #2 Image #3
Add Note Edit Step 7  ¶
  • With one hand, push the keyboard ribbon cable in slightly to access the ZIF connector beneath it.
  • Use a spudger to flip up the retaining flap.
  • Gently slide the cable out of the connector.
Image #1
Add Note Edit Step 8  ¶
  • Remove the six 1.5 mm Phillips #00 screws holding the trackpad in place.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
T5 Torx Screwdriver
$6.95 · 50+ In stock
Related Products
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 24 In stock
Inspection Scope
$39.95 · 39 In stock
Frictionless Ratchet
$24.95 · 48 In stock
Portable Anti-Static Mat
$24.95 · 17 In stock
