Installing Mac Mini Mid 2011 Hard Drive Replacement
Replace your Mac Mini's Mid 2011 hard drive for more storage space.
  • Add Note x
  • x 76
Use this guide to completely replace your mini's hard drive.
Image #1 Image #2
Add Note Edit Step 1 — Bottom Cover  ¶
  • Place your thumbs in the depressions cut into the bottom cover.
  • Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
Image #1
Add Note Edit Step 2  ¶
  • Tilt the mini enough to allow the bottom cover to fall away from the outer case.
  • Remove the bottom cover and set it aside.
Image #1
Add Note Edit Step 3 — Fan  ¶
  • Remove the two 11.3 mm T6 Torx screws securing the fan to the logic board near the antenna plate.
Image #1
Add Note Edit Step 4  ¶
  • Lift the ear of the fan nearest the RAM up off the standoff secured to the outer case.
  • Removing the standoff screw is not necessary to remove the fan. You need only raise the fan enough to lift it off the standoff screw.
Image #1
Add Note Edit Step 5  ¶
  • Lift the fan out of the mini for enough clearance to access its connector.
  • Carefully pull the fan cables upward to lift the fan connector up out of its socket on the logic board.
  • Remove the fan.
Image #1
Add Note Edit Step 6 — Cowling  ¶
  • Remove the single 3.5 mm T6 Torx screw securing the cowling to the heat sink.
Image #1
Add Note Edit Step 7  ¶
  • Lift the cowling from the end nearest the antenna plate.
  • Rotate the cowling away from the outer case and remove it from the mini.
Image #1
Add Note Edit Step 8 — Antenna Plate  ¶
  • Remove the following screws securing the antenna plate to the mini:
    • Two 6.6 mm T8 Torx screws
    • Two 5.0 mm T8 Torx or 2.0 mm Hex screws (either screwdriver will work)
Next » « Previous
Required Tools
T8 Torx Security Bit Screwdriver
$6.95 · 50+ In stock
Spudger
$2.95 · 50+ In stock
T6 Torx Screwdriver
$4.95 · 50+ In stock
54 Bit Driver Kit
$24.95 · 50+ In stock
Mac Mini Logic Board Removal Tool
$4.95 · 33 In stock
Related Products
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 17 In stock
Inspection Scope
$39.95 · 38 In stock
Frictionless Ratchet
$24.95 · 48 In stock
Portable Anti-Static Mat
$24.95 · 16 In stock
