How to Free Wheelchair Mission GEN 1
  1. How to Free Wheelchair Mission GEN 1, Remove Rear Wheel: step 1, image 1 of 3 How to Free Wheelchair Mission GEN 1, Remove Rear Wheel: step 1, image 2 of 3 How to Free Wheelchair Mission GEN 1, Remove Rear Wheel: step 1, image 3 of 3
    • Unscrew the axle bolt Using the Free Wheelchair Mission Custom Multi-Purpose Tool on the bolt head and a 19mm crescent wrench on the nut.
    • Remove the wheel and set it aside.
    • You can also use a 19mm socket instead of the multitool.
  2. How to Free Wheelchair Mission GEN 1, Remove Cap of Tube Stem: step 2, image 1 of 2 How to Free Wheelchair Mission GEN 1, Remove Cap of Tube Stem: step 2, image 2 of 2
    • Unscrew the cap of the tube stem and set it aside.
  3. How to Free Wheelchair Mission GEN 1, Release Air From The Tire: step 3, image 1 of 2 How to Free Wheelchair Mission GEN 1, Release Air From The Tire: step 3, image 2 of 2
    • Release any air that remains by pressing down on the piston in the head of the stem.
  4. How to Free Wheelchair Mission GEN 1: step 4, image 1 of 3 How to Free Wheelchair Mission GEN 1: step 4, image 2 of 3 How to Free Wheelchair Mission GEN 1: step 4, image 3 of 3
    • Take a tire lever and fit it under the edge of the tire.
    • Pop the edge of the tire out of the rim of the wheel by pushing down on the lever.
    • Clip the opposite end of the lever onto the closest spoke.
  5. How to Free Wheelchair Mission GEN 1: step 5, image 1 of 1
    • Take another tire lever and repeat step 4 roughly 2.5 inches away from where you are holding the other tire lever.
  6. How to Free Wheelchair Mission GEN 1: step 6, image 1 of 1
    • Holding one tire lever in place, slide the other lever around the rest of the wheel until the side of the tire is completely free of the rim.
  7. How to Free Wheelchair Mission GEN 1: step 7, image 1 of 2 How to Free Wheelchair Mission GEN 1: step 7, image 2 of 2
    • Push the stem of the tube back through the hole in the rim it comes out of.
    • Reach under the tire and pull the tube out.
  8. How to Free Wheelchair Mission GEN 1: step 8, image 1 of 2 How to Free Wheelchair Mission GEN 1: step 8, image 2 of 2
    • Unfold the new tube and unscrew the cap of the stem.
    • Set the cap aside someplace safe. You will need to put it back on later.
  9. How to Free Wheelchair Mission GEN 1: step 9, image 1 of 2 How to Free Wheelchair Mission GEN 1: step 9, image 2 of 2
    • Fit the stem of the tube firmly into the hole in the pump that comes on the frame.
    • Lift the lever on the head of the pump up.
  10. How to Free Wheelchair Mission GEN 1: step 10, image 1 of 3 How to Free Wheelchair Mission GEN 1: step 10, image 2 of 3 How to Free Wheelchair Mission GEN 1: step 10, image 3 of 3
    • Pull the handle of the piston at the bottom of the pump out.
    • Pump a small amount of air into the tube so that it holds its basic shape.
    • To pump air into the tube pull the piston out then push it back in.
  11. How to Free Wheelchair Mission GEN 1: step 11, image 1 of 2 How to Free Wheelchair Mission GEN 1: step 11, image 2 of 2
    • Push the stem of the tube through the hole in the rim so that the head is on the outside.
    • Push the rest of the tube under the tire so it sits evenly on the rim.
  12. How to Free Wheelchair Mission GEN 1: step 12, image 1 of 2 How to Free Wheelchair Mission GEN 1: step 12, image 2 of 2
    • Push the tire back onto the rim working your hands around the wheel.
    • Pump air into the tube until the tire is firm and can support you weight.
    • Screw the cap back onto the head of the tube stem.
    • If you have a pressure gauge it should read around 40 psi.
  13. How to Free Wheelchair Mission GEN 1: step 13, image 1 of 2 How to Free Wheelchair Mission GEN 1: step 13, image 2 of 2
    • Put the wheel back on the axle and screw in the bolt using the multitool or 19mm socket and 19mm crescent wrench.
    • Make sure the handle faces out.
Finish Line
2 other people completed this guide.
Attached Documents
Andrew Blocher
85 Reputation
1 Guide authored
Cal Poly, Team 14-7, Maness Spring 2013 Member of Cal Poly, Team 14-7, Maness Spring 2013
CPSU-MANESS-S13S14G7
5 Members
7 Guides authored
One Comment
Goodness, What an outstanding Post. I found this is an excess of information. It is the thing I was looking for. I might want to suggest you that’s if its not too much trouble, continue to share such short info. If conceivable, Thanks
''GadgetBox Sell Defferent kinds of Wheelchair in minimum budgets in Bangladesh''
Joseph M Smith - Reply
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 16
All Time: 1,356
