Introduction
Here are the tools you will need in order to assemble, disassemble, and fix your Free Wheelchair Mission GEN 1 wheelchair.
  1. The 10mm wrench that comes attached to the footrest of the GEN 1 wheelchair fits the majority of nuts and bolts that hold together the GEN 1 wheelchair The 10mm wrench that comes attached to the footrest of the GEN 1 wheelchair fits the majority of nuts and bolts that hold together the GEN 1 wheelchair
    • The 10mm wrench that comes attached to the footrest of the GEN 1 wheelchair fits the majority of nuts and bolts that hold together the GEN 1 wheelchair
  2. The multi-purpose tool comes with the GEN 1 wheelchair and fits all nuts and bolts ranging from the 19mm bolt holding the rear wheels to the 10mm bolts that hold the wheelchair together
    • The multi-purpose tool comes with the GEN 1 wheelchair and fits all nuts and bolts ranging from the 19mm bolt holding the rear wheels to the 10mm bolts that hold the wheelchair together
    • This socket fits the 19mm bolt
    • This socket fits the 10mm bolt
  3. This 10mm T-Wrench will fit all 10mm nuts and bolts that hold together the GEN 1 wheelchair
    • This 10mm T-Wrench will fit all 10mm nuts and bolts that hold together the GEN 1 wheelchair
  4. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    Browse Our Store
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  5. The tire pump may be used to inflate the rear wheels
    • The tire pump may be used to inflate the rear wheels
  6. The pliers are best for holding nuts in place while assembling and disassembling all bolts
    • The pliers are best for holding nuts in place while assembling and disassembling all bolts
    • The pliers are not included with the GEN 1 wheelchair
  7. This wrench will fit the 19mm nuts and bolts holding the rear wheels to the wheelchair and the 19mm nuts and bolts holding the castor wheels to their posts
    • This wrench will fit the 19mm nuts and bolts holding the rear wheels to the wheelchair and the 19mm nuts and bolts holding the castor wheels to their posts
    • This tool does not come with the GEN 1 wheelchair but may be used in place of the Free Wheelchair Mission Multi-Purpose tool for the assembly and disassembly of the rear wheels and castor wheels
  8. This wrench may be used for the assembly and disassembly of all 10mm nuts and bolts holding together the GEN 1 wheelchair
    • This wrench may be used for the assembly and disassembly of all 10mm nuts and bolts holding together the GEN 1 wheelchair
    • This tool does not come with the GEN 1 wheelchair but may be used in place of the T-Wrench or Free Wheelchair Mission 10mm wrench
  9. These tools are used for the removal of the tire from the bicycle wheel in order to get to the inner bicycle tube
    • These tools are used for the removal of the tire from the bicycle wheel in order to get to the inner bicycle tube
  10. This wrench will fit the 19mm nuts and bolts holding the rear wheels to the wheelchair and the 19mm nuts and bolts holding the castor wheels to their posts
2 other people completed this guide.
Mike Sevilla
180 Reputation
4 Guides authored
Cal Poly, Team 14-7, Maness Spring 2013 Member of Cal Poly, Team 14-7, Maness Spring 2013
CPSU-MANESS-S13S14G7
5 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 1,096
