HTC Vive XR Elite Battery Cradle Power LED Replacement
  1. HTC Vive XR Elite Battery Cradle Power LED Replacement, Prepare your Vive XR Elite for disassembly: step 1, image 1 of 1
    • Before starting this repair, discharge the batteries in your headset below 25%. A charged battery may leak dangerous chemicals or catch fire if damaged.
    • Playing Half Life: Alyx will do the trick!
    • The Vive XR Elite has a proximity sensor that puts the headset in standby mode to save battery when it isn't in use. To drain the battery faster you'll need to use the headset.
  2. HTC Vive XR Elite Battery Cradle Power LED Replacement, Disconnect the USB-C power cable: step 2, image 1 of 2 HTC Vive XR Elite Battery Cradle Power LED Replacement, Disconnect the USB-C power cable: step 2, image 2 of 2
    • Disconnect the USB-C power cable.
  3. HTC Vive XR Elite Battery Cradle Power LED Replacement, Disconnect the battery cradle: step 3, image 1 of 3 HTC Vive XR Elite Battery Cradle Power LED Replacement, Disconnect the battery cradle: step 3, image 2 of 3 HTC Vive XR Elite Battery Cradle Power LED Replacement, Disconnect the battery cradle: step 3, image 3 of 3
    • Press the release button on the right battery cradle temple slot.
    • Pull the battery cradle away from the right temple slot to disconnect it.
  4. HTC Vive XR Elite Battery Cradle Power LED Replacement: step 4, image 1 of 3 HTC Vive XR Elite Battery Cradle Power LED Replacement: step 4, image 2 of 3 HTC Vive XR Elite Battery Cradle Power LED Replacement: step 4, image 3 of 3
    • Repeat the previous step for the left temple slot.
  5. HTC Vive XR Elite Battery Cradle Power LED Replacement, Separate the headset and battery cradle: step 5, image 1 of 1
    • Separate the headset and battery cradle.
  6. HTC Vive XR Elite Battery Cradle Power LED Replacement, Insert an opening pick: step 6, image 1 of 2 HTC Vive XR Elite Battery Cradle Power LED Replacement, Insert an opening pick: step 6, image 2 of 2
    • Insert a long edge of an opening pick in the gap between the two halves of the battery cradle, near the USB-C cable.
  7. HTC Vive XR Elite Battery Cradle Power LED Replacement, Release the top clips: step 7, image 1 of 3 HTC Vive XR Elite Battery Cradle Power LED Replacement, Release the top clips: step 7, image 2 of 3 HTC Vive XR Elite Battery Cradle Power LED Replacement, Release the top clips: step 7, image 3 of 3
    • Slide the opening pick along the top edge of battery cradle to release its plastic clips.
  8. HTC Vive XR Elite Battery Cradle Power LED Replacement: step 8, image 1 of 2 HTC Vive XR Elite Battery Cradle Power LED Replacement: step 8, image 2 of 2
    • Flip the battery cradle over.
    • Insert the long edge of an opening pick in the gap between the two halves of the battery cradle.
  9. HTC Vive XR Elite Battery Cradle Power LED Replacement, Release the bottom clips: step 9, image 1 of 3 HTC Vive XR Elite Battery Cradle Power LED Replacement, Release the bottom clips: step 9, image 2 of 3 HTC Vive XR Elite Battery Cradle Power LED Replacement, Release the bottom clips: step 9, image 3 of 3
    • Slide the opening pick along the bottom edge of battery cradle to release its plastic clips.
  10. HTC Vive XR Elite Battery Cradle Power LED Replacement, Separate the battery cradle halves: step 10, image 1 of 2 HTC Vive XR Elite Battery Cradle Power LED Replacement, Separate the battery cradle halves: step 10, image 2 of 2
    • Pull apart the two halves of the battery cradle to completely separate them.
  11. HTC Vive XR Elite Battery Cradle Power LED Replacement, Peel back the graphite thermal tape: step 11, image 1 of 3 HTC Vive XR Elite Battery Cradle Power LED Replacement, Peel back the graphite thermal tape: step 11, image 2 of 3 HTC Vive XR Elite Battery Cradle Power LED Replacement, Peel back the graphite thermal tape: step 11, image 3 of 3
    Tool used on this step:
    Buy
    • Use tweezers to peel back the graphite thermal tape covering the inner plastic frame.
    • If the tape tears a little, don't worry! During reassembly, stick it back in its original place as if it were still one piece
  12. HTC Vive XR Elite Battery Cradle Power LED Replacement, Unfasten the inner plastic frame: step 12, image 1 of 2 HTC Vive XR Elite Battery Cradle Power LED Replacement, Unfasten the inner plastic frame: step 12, image 2 of 2
    FixMat
    $36.95
    Buy
    • Use a T5 Torx screwdriver to remove the nine screws securing the inner plastic frame:
    • Five 11.8 mm-long screws
    • Three 5.6 mm-long screws
    • One 5.6 mm-long screw
    • This screw is covered by a piece of black plastic tape. Use tweezers to remove it before unscrewing.
  13. HTC Vive XR Elite Battery Cradle Power LED Replacement, Remove the inner plastic frame: step 13, image 1 of 2 HTC Vive XR Elite Battery Cradle Power LED Replacement, Remove the inner plastic frame: step 13, image 2 of 2
    • Remove the inner plastic frame, making sure to thread the graphite thermal tape through it.
  14. HTC Vive XR Elite Battery Cradle Power LED Replacement, Unfasten the headstrap clips: step 14, image 1 of 2 HTC Vive XR Elite Battery Cradle Power LED Replacement, Unfasten the headstrap clips: step 14, image 2 of 2
    • Use a T5 Torx screwdriver to remove the two 5.6 mm-long screws securing the headstrap clips.
  15. HTC Vive XR Elite Battery Cradle Power LED Replacement, Remove the headstrap clips: step 15, image 1 of 3 HTC Vive XR Elite Battery Cradle Power LED Replacement, Remove the headstrap clips: step 15, image 2 of 3 HTC Vive XR Elite Battery Cradle Power LED Replacement, Remove the headstrap clips: step 15, image 3 of 3
    Buy
    • Use tweezers to remove the left and right headstrap clips.
  16. HTC Vive XR Elite Battery Cradle Power LED Replacement, Peel back the battery board thermal pad: step 16, image 1 of 3 HTC Vive XR Elite Battery Cradle Power LED Replacement, Peel back the battery board thermal pad: step 16, image 2 of 3 HTC Vive XR Elite Battery Cradle Power LED Replacement, Peel back the battery board thermal pad: step 16, image 3 of 3
    Buy
    • Use tweezers or your fingers to peel back the thermal pad covering the battery board.
    • Work slowly to avoid tearing the thermal pad.
  17. HTC Vive XR Elite Battery Cradle Power LED Replacement, Disconnect the batteries: step 17, image 1 of 3 HTC Vive XR Elite Battery Cradle Power LED Replacement, Disconnect the batteries: step 17, image 2 of 3 HTC Vive XR Elite Battery Cradle Power LED Replacement, Disconnect the batteries: step 17, image 3 of 3
    • Use the flat end of a spudger to push the left and right battery cell connectors out of their respective sockets.
  18. HTC Vive XR Elite Battery Cradle Power LED Replacement, Disconnect the power LED: step 18, image 1 of 3 HTC Vive XR Elite Battery Cradle Power LED Replacement, Disconnect the power LED: step 18, image 2 of 3 HTC Vive XR Elite Battery Cradle Power LED Replacement, Disconnect the power LED: step 18, image 3 of 3
    • Use the point of a spudger to flip up the locking flap on the power LED ZIF connector.
    • Use tweezers or your fingers to disconnect the power LED cable.
    • During reassembly, slide the cable into the connector and close the locking flap. If the cable is getting stuck, gently remove it and realign it before trying again.
  19. HTC Vive XR Elite Battery Cradle Power LED Replacement, Disconnect the USB-C power cable: step 19, image 1 of 2 HTC Vive XR Elite Battery Cradle Power LED Replacement, Disconnect the USB-C power cable: step 19, image 2 of 2
    • Pull the black tab straight up on the USB-C power cable to disconnect it.
    • During reassembly, align the cable directly over the connector and press straight down to reconnect it.
  20. HTC Vive XR Elite Battery Cradle Power LED Replacement, Peel back the conductive tape: step 20, image 1 of 2 HTC Vive XR Elite Battery Cradle Power LED Replacement, Peel back the conductive tape: step 20, image 2 of 2
    • Use tweezers or your fingers to peel the conductive tape away from the front metal battery enclosure.
  21. HTC Vive XR Elite Battery Cradle Power LED Replacement, Unfasten the battery board: step 21, image 1 of 2 HTC Vive XR Elite Battery Cradle Power LED Replacement, Unfasten the battery board: step 21, image 2 of 2
    • Use a T5 Torx screwdriver to remove the four 4.1 mm-long screws securing the battery board.
  22. HTC Vive XR Elite Battery Cradle Power LED Replacement, Remove the battery board: step 22, image 1 of 2 HTC Vive XR Elite Battery Cradle Power LED Replacement, Remove the battery board: step 22, image 2 of 2
    • Remove the battery board.
  23. HTC Vive XR Elite Battery Cradle Power LED Replacement, Unfasten the front metal battery cover: step 23, image 1 of 2 HTC Vive XR Elite Battery Cradle Power LED Replacement, Unfasten the front metal battery cover: step 23, image 2 of 2
    • Use a T5 Torx screwdriver to remove the three screws securing the front metal battery enclosure:
    • Two 11.8 mm-long screws
    • One 4.8 mm-long screw
  24. HTC Vive XR Elite Battery Cradle Power LED Replacement, Unclip the USB-C power cable: step 24, image 1 of 2 HTC Vive XR Elite Battery Cradle Power LED Replacement, Unclip the USB-C power cable: step 24, image 2 of 2
    • Slide the USB-C power cable to the left to unclip it.
  25. HTC Vive XR Elite Battery Cradle Power LED Replacement, Remove the front metal battery enclosure: step 25, image 1 of 2 HTC Vive XR Elite Battery Cradle Power LED Replacement, Remove the front metal battery enclosure: step 25, image 2 of 2
    • Remove the front metal battery enclosure.
  26. HTC Vive XR Elite Battery Cradle Power LED Replacement, Reposition the battery cradle: step 26, image 1 of 1
    • Stand the battery cradle upright so the battery cells can fold flat on your work surface.
  27. HTC Vive XR Elite Battery Cradle Power LED Replacement, Remove the rear metal battery enclosure: step 27, image 1 of 2 HTC Vive XR Elite Battery Cradle Power LED Replacement, Remove the rear metal battery enclosure: step 27, image 2 of 2
    • Remove the rear metal battery enclosure.
  28. HTC Vive XR Elite Battery Cradle Power LED Replacement, Remove the power LED: step 28, image 1 of 3 HTC Vive XR Elite Battery Cradle Power LED Replacement, Remove the power LED: step 28, image 2 of 3 HTC Vive XR Elite Battery Cradle Power LED Replacement, Remove the power LED: step 28, image 3 of 3
    Buy
    • Use tweezers to pull out and remove the power LED.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Chayton Ritter
18,791 Reputation
102 Guides authored
Guide Team Member of Guide Team
Staff
7 Members
7,905 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 69
