DELL XPS 15 9560 with FHD non Glare TFT / Display Replacement
  1. DELL XPS 15 9560 with FHD non Glare TFT / Display  Replacement, Fold the hinges forward: step 1, image 1 of 2 DELL XPS 15 9560 with FHD non Glare TFT / Display  Replacement, Fold the hinges forward: step 1, image 2 of 2
    • The hinges are first folded forward. They're tight and require some force.
  2. DELL XPS 15 9560 with FHD non Glare TFT / Display  Replacement, Slide the WiFi antenna cover (between the hinges) to the right: step 2, image 1 of 1
    • Slide the WiFi antenna cover (between the hinges) to the right until it rests against the right hinge. It takes some strength to do that. Lift cover and set aside.
  3. DELL XPS 15 9560 with FHD non Glare TFT / Display  Replacement, Remove the hinges: step 3, image 1 of 2 DELL XPS 15 9560 with FHD non Glare TFT / Display  Replacement, Remove the hinges: step 3, image 2 of 2
    • under the black tape are three screws. Unscrew these screws and the hinge can be loosened. Place the hinge and screws in a small bowl.
  4. DELL XPS 15 9560 with FHD non Glare TFT / Display  Replacement, Remove the WiFi antenna: step 4, image 1 of 1
    • The WiFi antenna is attached with four screws. Unscrew the screws, place the antenna and screws in a bowl.
  5. DELL XPS 15 9560 with FHD non Glare TFT / Display  Replacement, Find two black threads: step 5, image 1 of 2 DELL XPS 15 9560 with FHD non Glare TFT / Display  Replacement, Find two black threads: step 5, image 2 of 2
    • One end of the same thread can be found near the screw holes of the hinges. The thread runs around between the cover and the TFT. The thread is marked in red here. It can also lie hidden in the depression, then fish out.
  6. DELL XPS 15 9560 with FHD non Glare TFT / Display  Replacement, Warm up the lid substantially.: step 6, image 1 of 1
    • The lid has to be heated up a lot because the TFT is glued. The glue will soften when the heat is there. The lid is made of metal, it takes time for the heat to emit to the inside. I used a seed pillow, or two next to each other. You can certainly use other methods...
  7. DELL XPS 15 9560 with FHD non Glare TFT / Display  Replacement, Pull out the threads: step 7, image 1 of 2 DELL XPS 15 9560 with FHD non Glare TFT / Display  Replacement, Pull out the threads: step 7, image 2 of 2
    • The right thread is pulled out. The thread has to be pulled around obstacles (plastic nose) from time to time. A plectrum or a wooden spatula can help to lift the display slightly. Then the thread has more space.
  8. DELL XPS 15 9560 with FHD non Glare TFT / Display  Replacement, The thread separates the glue: step 8, image 1 of 1
    • The thread cuts the adhesive strip behind the TFT along the narrow side. I wrapped the thread around the pliers so that you can apply the necessary pull. Only cut up to the upper long side. There is no glue on the long side. Do the same on the other side. Insert spacers, otherwise the TFT will stick again.
  9. DELL XPS 15 9560 with FHD non Glare TFT / Display  Replacement, Lift out the TFT: step 9, image 1 of 2 DELL XPS 15 9560 with FHD non Glare TFT / Display  Replacement, Lift out the TFT: step 9, image 2 of 2
    • The TFT can be removed. On the inside of the lid you can see the guides for the thread. The cut adhesive strips can be seen on the display.
    • Second photo: The cutting thread is on the display. A good idea from the developers at Dell :-). If you really want it to stick.
  10. DELL XPS 15 9560 with FHD non Glare TFT / Display  Replacement, Detach the thermal pad: step 10, image 1 of 1
    • Carefully remove the heat-conducting pad with a blade and place it on a foil. Mark the position of the cushions.
  11. DELL XPS 15 9560 with FHD non Glare TFT / Display  Replacement, Remove the aluminum foil from the camera: step 11, image 1 of 1
    • Peel off the thick aluminum foil covering the camera cable. save aluminum foil.
  12. DELL XPS 15 9560 with FHD non Glare TFT / Display  Replacement, Disconnect the display cables: step 12, image 1 of 2 DELL XPS 15 9560 with FHD non Glare TFT / Display  Replacement, Disconnect the display cables: step 12, image 2 of 2
    • Remove the adhesive tape over the display connector. Fold down the brackets, pull the plug outwards. Unplug the camera connection cable. Detach the camera connection point (warm it up).
    • Carefully peel off the attached camera. IMPORTANT! The camera has to be glued back to the new display in exactly the same place. The hole in the display frame is small.
    • Important! The camera needs to be put back in very exactly the same place on the new display.
    • Insert, fold over the brackets, reattach the adhesive tape.
    • Fasten both as precisely as possible to the new TFT.
    • This was the most annoying step for me. The thin aluminum frame is attached to the TFT with a lot of adhesive. The glue is very strong. A lot of heat helps here again. Warning: The thin frame must not be bent. He can certainly break too. Carefully remove piece by piece and place pieces of wood in between
    • The frame must be freed from all adhesive residues. Don't scratch the inner edge, otherwise you'll see it later because it's no longer black...
    • If you want to take the risk of not getting the lid out, you can save yourself this. I put the thread back in the groove it was in. The thread is very important to me. There are stickers that hold the thread in place.
    • I used thin carpet tape without grid thread for reinforcement.
    • Check everything again. Do not remove the foil from the adhesive tape yet. Try inserting the display. Put on the display frame as a test. Can the camera be seen through the hole in the frame? Are the ends of the threads in the right place? If everything is correct, go to step 22
    • Remove the protective film from the adhesive tape. Insert the tabs of the display at the top of the lid, lower the display.
    • I put double sided tape on the back of the frame. Black tape would be ideal. I didn't want to use liquid glue or Sikaflex, so only double-sided tape was an option. There shouldn't be any tape sticking out, I used a sharp blade to cut it.
    • Remove the protective film from the adhesive tape and glue the frame in place. Press firmly all around.
    • I save myself the further instructions. Reassemble all components to the lid and screw the display assembly into place. From here use the Dell service manual again and be happy with the new display without dead pixels.
    • Another device saved that has enough power even by today's standards and can still be used for years to come
Follow the steps in reverse order to reassemble your device.
Special thanks to these translators:
de en
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
Attached Documents
Michael Graf
361 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 52
All Time: 1,326
