Black and Decker CM0700BZ Water Tank Replacement
  1. Black and Decker CM0700BZ Water Tank Replacement, Lid: step 1, image 1 of 2 Black and Decker CM0700BZ Water Tank Replacement, Lid: step 1, image 2 of 2
    • Open the lid of the coffee maker.
    • Remove the brew cup.
  2. Black and Decker CM0700BZ Water Tank Replacement: step 2, image 1 of 3 Black and Decker CM0700BZ Water Tank Replacement: step 2, image 2 of 3 Black and Decker CM0700BZ Water Tank Replacement: step 2, image 3 of 3
    • Place your finger, screwdriver, or spudger behind the corner of the tab.
    • Pull up on the tab until it disconnects from the coffee maker.
  3. Black and Decker CM0700BZ Water Tank Replacement: step 3, image 1 of 3 Black and Decker CM0700BZ Water Tank Replacement: step 3, image 2 of 3 Black and Decker CM0700BZ Water Tank Replacement: step 3, image 3 of 3
    • Hold the tab while pushing back on the lid.
    • The lid should open fully with the top of the lid facing down.
  4. Black and Decker CM0700BZ Water Tank Replacement: step 4, image 1 of 2 Black and Decker CM0700BZ Water Tank Replacement: step 4, image 2 of 2
    • Insert the flathead screwdriver or spudger into one of the inserts holding the lid.
    • Pry facing away from the lid to force the peg out.
    • You should hear a pop when it disconnects.
    • Hold the lid and pull it away from the other insert.
  5. Black and Decker CM0700BZ Water Tank Replacement: step 5, image 1 of 1
    • To also remove the shower head, use the Shower Head guide.
  6. Black and Decker CM0700BZ Water Tank Replacement, Water Tank: step 6, image 1 of 2 Black and Decker CM0700BZ Water Tank Replacement, Water Tank: step 6, image 2 of 2
    • Remove the carafe holder from the bottom of the coffee machine.
  7. Black and Decker CM0700BZ Water Tank Replacement: step 7, image 1 of 3 Black and Decker CM0700BZ Water Tank Replacement: step 7, image 2 of 3 Black and Decker CM0700BZ Water Tank Replacement: step 7, image 3 of 3
    • Place coffee maker on its side, with the bottom facing you.
    • Remove two 10mm Phillips #1 screws and one 10mm Tri-Point Y1 screws with their designated tips.
  8. Black and Decker CM0700BZ Water Tank Replacement: step 8, image 1 of 3 Black and Decker CM0700BZ Water Tank Replacement: step 8, image 2 of 3 Black and Decker CM0700BZ Water Tank Replacement: step 8, image 3 of 3
    • Slowly pry the bottom lid from the front.
    • You should hear a pop.
    • Pull up and remove the bottom lid.
  9. Black and Decker CM0700BZ Water Tank Replacement: step 9, image 1 of 1
  10. Black and Decker CM0700BZ Water Tank Replacement: step 10, image 1 of 3 Black and Decker CM0700BZ Water Tank Replacement: step 10, image 2 of 3 Black and Decker CM0700BZ Water Tank Replacement: step 10, image 3 of 3
    • Remove the four 10 mm Phillips #1 screws.
    • Slowly pull the water tank up to expose the water pipes
  11. Black and Decker CM0700BZ Water Tank Replacement: step 11, image 1 of 2 Black and Decker CM0700BZ Water Tank Replacement: step 11, image 2 of 2
    Tool used on this step:
    Buy
    • Squeeze on the prongs with tweezers and hold.
    • Pull the water tank while squeezing the tighteners to loosen the water pipes off of the water tank.
Shawn Robichaud
729 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 27
All Time: 237
