1986-1993 Volvo 240 Front Brake Rotors Replacement
  1. 1986-1993 Volvo 240 Front Brake Rotors Replacement, Front Wheels: step 1, image 1 of 3 1986-1993 Volvo 240 Front Brake Rotors Replacement, Front Wheels: step 1, image 2 of 3 1986-1993 Volvo 240 Front Brake Rotors Replacement, Front Wheels: step 1, image 3 of 3
    • Jack up the front of the car and place it on jack stands.
    • Never work on or underneath a car that is only supported by a jack. The jack may slip or fail, resulting in serious injury or even death.
    • Use an impact wrench or lug wrench to remove the five 19 mm lug nuts from the front wheel.
    • The wheel lug nuts should be torqued to 85 ft-lbs when the wheels are put back on the car.
    • Pull the front wheel off the wheel lugs and set it aside.
  2. 1986-1993 Volvo 240 Front Brake Rotors Replacement, Front Brake Calipers: step 2, image 1 of 2 1986-1993 Volvo 240 Front Brake Rotors Replacement, Front Brake Calipers: step 2, image 2 of 2
    • Use a 15 mm box end wrench to remove the two bolts on the back of the brake caliper.
  3. 1986-1993 Volvo 240 Front Brake Rotors Replacement: step 3, image 1 of 2 1986-1993 Volvo 240 Front Brake Rotors Replacement: step 3, image 2 of 2
    • Lift the brake caliper off the rotor and set it aside.
    • Place the caliper on some type of support so that you do not put too much strain on the brake hose.
  4. 1986-1993 Volvo 240 Front Brake Rotors Replacement, Front Brake Rotors: step 4, image 1 of 1
    • Pull the brake rotor straight off the wheel lugs to remove it.
  5. 1986-1993 Volvo 240 Front Brake Rotors Replacement: step 5, image 1 of 1
    • Place the new brake rotor over the wheel lugs.
    • Most new brake rotors can be installed without any additional work, but if your rotors are out of round they will need to be turned.
To reassemble your device, follow these instructions in reverse order starting at Step 3.
3 other people completed this guide.
Brett Hartt
128,027 Reputation
143 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,520 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 21
All Time: 6,528
