Battery
1 Answer 0 Score |
Need to change processor |
1 Answer 0 Score |
Switched hard drives. Now won't startup. |
1 Answer 0 Score |
No Display or Disk activity. |
1 Answer 0 Score |
Laptop not loading Windows setup |
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Troubleshooting
If you are having trouble identifying the problem with your Toshiba Satellite L775D-S7340 visit this Troubleshooting Page.
Background
Originally released in 2011, the Toshiba Satellite L775D-S7340 was a laptop geared towards gamers with its adjustable LED background and higher resolution. This Toshiba Satellite model stands out from past models because of its 17.3 inch display, full key board with a ten-key pad, sleek brushed blue metallic paint job, and spacious trackpad. Although the initial operating system used for this laptop was Windows 7, the OS driver should accommodate an upgrade to Windows 10.
Specifications
- Quad Core AMD processor
- 6GB RAM
- 640 GB Hard Disk
- Blu-ray Player
- HDMI, 3 USB, and RGB ports
- Wireless & RJ-45LAN jack
- HD +TruBrite LED backlit display
- Built-in Web cam and mic
The only recall associated with the Toshiba Satellite L775D-S7340 is a general battery recall. The recall was not specific to this laptop, but all Toshiba laptop batteries; scroll down further to see the provided link to Toshiba's Battery Replacement Program.
Identification
The quickest and easiest way to determine whether your laptop is a Toshiba Satellite L775D-S7340 is to look at the manufacturer's sticker on the bottom side of the laptop. If it is, the sticker will have the full Toshiba Satellite L775D-S7340 name displayed near the top left corner.
Additional Information
Review on Toshiba Satellite L775D-S7340
Toshiba Satellite Wikipedia Page
Support Page on Toshiba Satellite L775D-S7340
Toshiba Troubleshooting Assisstant
