Toshiba Satellite L775D-S7340 Keyboard Replacement
  1. Toshiba Satellite L775D-S7340 Keyboard Replacement, Battery: step 1, image 1 of 1
    • Make sure the laptop is unplugged and powered off.
    • Locate the battery latches on the underside of the laptop.
  2. Toshiba Satellite L775D-S7340 Keyboard Replacement: step 2, image 1 of 1
    • Slide the right latch to the right until you hear it lock into place.
    • Slide the left latch to the left and hold it.
  3. Toshiba Satellite L775D-S7340 Keyboard Replacement: step 3, image 1 of 1
    • Slide the battery out towards you.
  4. Toshiba Satellite L775D-S7340 Keyboard Replacement, Keyboard: step 4, image 1 of 1
    • Pry up the thin narrow strip of facing above the keyboard using the opening tool.
  5. Toshiba Satellite L775D-S7340 Keyboard Replacement: step 5, image 1 of 1
    • Remove the four screws securing the keyboard using the T4 Torx screwdriver,
  6. Toshiba Satellite L775D-S7340 Keyboard Replacement: step 6, image 1 of 2 Toshiba Satellite L775D-S7340 Keyboard Replacement: step 6, image 2 of 2
    • Lift the keyboard slowly using the opening tool and lean it toward touchpad.
    • It will still be held by the connector ribbon. Make sure not to pull out the connector ribbon.
  7. Toshiba Satellite L775D-S7340 Keyboard Replacement: step 7, image 1 of 1
    • The ribbon is attached by a white clip. Wedge the white clip up carefully using the spudger. This will release the connector ribbon and you can now remove the keyboard.
Madeline Park
441 Reputation
4 Guides authored
One Comment
I need to know how to change a plasma for a Toshiba Satellite L775D-S7340
Cyndi May Evans - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 12
All Time: 1,700
