Clamp
1 Answer 0 Score |
Why is are my fan blades not spinning quickly? |
2 Answers 0 Score |
Can I add a drop of oil to small fan motor? Where? |
2 Answers 0 Score |
Why is my fan overheating? |
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The Comfort Zone CZ6C is a small, 6” fan that can be clamped onto multiple surfaces. The CZ6C comes with a two-speed switch and an adjustable tilt. The external casing consists of a grey plastic, with a removable safety grill over the fan blade.
Identification
The serial identification number for the Comfort Zone CZ6C can be found on the bottom surface of the clamp.
Technical Specs
- 26 x 12 x 12.5 inches
- Weight: 2.9 lbs
- Blade Diameter: 6 inches
