Comfort Zone CZ6C Motor Replacement
  1. Comfort Zone CZ6C Motor Replacement, Motor: step 1, image 1 of 3 Comfort Zone CZ6C Motor Replacement, Motor: step 1, image 2 of 3 Comfort Zone CZ6C Motor Replacement, Motor: step 1, image 3 of 3
    • Make sure to unplug the Comfort Zone CZ6C before replacing the motor. This will prevent the risk of electrocution.
    • Unscrew the main housing screw located right above the main switch using a Phillips screwdriver.
    • Then use gentle force to remove the main housing door.
    • Remember to keep track of your screws!
  2. Comfort Zone CZ6C Motor Replacement: step 2, image 1 of 3 Comfort Zone CZ6C Motor Replacement: step 2, image 2 of 3 Comfort Zone CZ6C Motor Replacement: step 2, image 3 of 3
    • Unscrew the two adjacent housing screws to free the motor cage from the housing.
  3. Comfort Zone CZ6C Motor Replacement: step 3, image 1 of 3 Comfort Zone CZ6C Motor Replacement: step 3, image 2 of 3 Comfort Zone CZ6C Motor Replacement: step 3, image 3 of 3
    • Remove the motor cage from the fan housing.
  4. Comfort Zone CZ6C Motor Replacement: step 4, image 1 of 2 Comfort Zone CZ6C Motor Replacement: step 4, image 2 of 2
    • Unscrew the two adjacent motor cage screws to free the motor
  5. Comfort Zone CZ6C Motor Replacement: step 5, image 1 of 3 Comfort Zone CZ6C Motor Replacement: step 5, image 2 of 3 Comfort Zone CZ6C Motor Replacement: step 5, image 3 of 3
    • The motor is now free to be replaced.
    • If the motor will not move out of its now freed state you can use WD-40 to loosen it
5 other people completed this guide.
Gage Wilson
217 Reputation
1 Guide authored
Cal Poly, Team 17-5, Forte Spring 2015 Member of Cal Poly, Team 17-5, Forte Spring 2015
CPSU-FORTE-S15S17G5
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 73
All Time: 5,587
