Score
Avatar
marcus
13
Asked
Has anybody tried heat to loosen battery glue?
History
The MBP Retina teardown uses brute force on the battery. Have you tried applying heat?
I would apply a heat-shrink style heat gun to the metal opposite whatever is stuck, right at the location where I'm prying. Do not directly heat the battery.
I haven't got an MBP Retina, but I've noticed the adhesives used in the old MBP respond to heat very well.
FWIW. Try this before solvent, which was suggested in another query. (Then try Goo-Gone, if you can avoid contaminating other components.)
Edited by: marcus ( )
Post Answer
2
Score
Avatar
danielh
25
Answered
PermalinkHistory
Score
Avatar
machead3
21.3k
Answered
PermalinkHistory
I would be very cautious suggesting the use of heat on these batteries, you risk fire. explosion, noxious fumes serious personal/property injury!! Apple's technicians have been told that the battery is not a replaceable part. their solution is to replace the top case assembly, to which the battery is fixed. IMnsHO encouraging a DIY to attempt this proces would be on the order of encouraging an amateur to work on a CRT--irresponsible and unprofessional.
The idea is to heat the glue, not the battery. These glues usually soften at a relatively low temperature: heat-shrink gun, not paint stripper! If it works, it's better than a putty knife, which is the solution already offered here. If you short one of these batteries it gets plenty hot all by itself. Certainly it is safest to replace the whole assembly; only a DIY will try otherwise, so it's as well the DIYs know what's involved first.
marcus,
0
Score
Avatar
volodymyrshuvayev
Answered
PermalinkHistory
Wow, cool! Thank you, this is very helpful!
Add Your Answer
