Repair guides and support for motherboards and CPUs.
166 Questions View all
type of power supply for supero x7dwt
I would like to know that I have that font installed on this motherboard Supero X7DWT for carrying two 20-pin connectors, and not whether an adapter for the two would serve me.
Update
then I want to say that only connects the jwr1. I have a 850 watt atx power should serve me then.
Score 1
Add a comment
1 Answer
Chosen Solution
ramon vale,
If your computer refuses to boot or tends to turn off without warning, see the Faulty Power Supply to Motherboard problem page for possible causes and solutions.
The manual for your motherboard states that "You cannot use both 20-pin power connectors located at JWR1 (the right side connector) and JWR2 (the left side connector) as input power supply connectors at the same time. Only one connector can be used for input power supply to the motherboard at one time. For proper use of these proprietary PWR Connectors, please customize your PWR cables based on the Power Connector Pin-Out Definitions listed on Page 2-14". You can download the manual from here. Hope this helps, good luck.
Score 1
6 Comments:
thank you...
by
You are welcome ;)
by
by
Yes, that should work well for you.
by
thank you very much again.
by
Show 1 more comment
Add a comment
Add your answer
ramon vale will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 15
All Time: 781
