One of the beige G3 series produced by Apple between 1997 and 1999.
2 Questions View all
HD ata, pata, ide and ultra ata
Hi, I own a Power Mac G3 desktop beige and I've bought a new HD Western Digital 80GB WD800AAJB 7200 rpm 8MB Caviar Blue PATA. The Mac sees the HD as it complies with G3 limitations (no bigger than 120), mounts it, formats it, uses it, but just for "normal" use, I mean writing, reading files. But when I try to use it in HD recording mode, with Pro Tools, the drive seems to work, but when I play recorded files, they appear to be fitted of spikes, and I get a crackly sound, like the old dusty vinyl one. If you examine the waveform, made with a sine test, you can find many, many spikes everywhere.
Can I fix it? may be with a special drive? Or is it an insoluble problem?
The OS is 9.2
Thanks to everybody
massimiliano
Score -1
Add a comment
1 Answer
Chosen Solution
The problem is new drives write too slow in "backwards compatible mode". This might be an option, but contact OWC to see if they have any other solutions or advice.
If this answer was helpful please remember to return an mark it Accepted.
Score 2
1 Comment:
Thanks! I see the solution by OWC is not compatible with my jurassic Mac. but I'll investigate this way.
by
Add a comment
Add your answer
Massimiliano Giusti will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 11
All Time: 439
