The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
781 Questions View all
Noticed blown resistor, what size resistor do I need?
While pulling my PS3 apart to fix the YLOD problem I saw the tell tale black mark on the mother board were one of the surface mount resistors blew. It has a 2 marked on the part. This part is located on the top of the mother board near the back at the HDMI port, directly below the board where it is marked COK-002 TH2501.
Has anyone else had this problem? What did you do?
More to the point, does anyone know what size I need to get and a quick place to get it?
The HDMI port is the first port next to the burnt spot on the board.
Score 1
1 Comment
Shawn, any chance you could post a couple of image on where it is and the proximity to other "landmarks" on the board. There are quite a few components in that general area. You can import images on here, so anyone looking at your question will see what you are asking.
by
Add a comment
1 Answer
Chosen Solution
That is a thermistor :"TH2501 part number:1-805-726-11 description THERMISTOR, POSITIVE You can try and do more of a parts search by that number. I just did a quick one and got this. Hope this helps, good luck.
Score 3
Add a comment
Add your answer
Shawn will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 14
All Time: 2,445
