This is the first generation of the Ford Escape, a compact crossover SUV. Production started in 2000 for the 2001 model year.
104 Questions View all
Rotor will not come off after pads and caliber removed.Are there some
The brake rotor does not come off after you remove pads and caliber.....is there some bolts on the back side of rotor holding it on. Your comments appreciated
Score -1
Add a comment
1 Answer
If it is a two-wheel drive, it should just be slightly pressed on. Sometimes a hammer will do the trick and loosen the rust and grime that may hold it on. If it is 4X4 or AWD :) check for a snap ring on the axle shaft.
Add a comment
Add your answer
Fred b will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 576
