0
Score
Asked
iPhone 4s replacement screen white around the edges
I replaced my iPhone 4S screen and when I restarted it everything looked ok. After a short while however the new screen started displaying a milky white glow along the edges. I've reopened it and checked the connectors but no luck. I'm also suspecting that it's spreading. The digitizer works fine.
Any ideas what may cause this and how to fix it?
Update: after letting it rest overnight the screen looked fine first thing in the morning, however the white 'halo' reappeared shortly after. Heatsink issue?
Edited by: Daniel Hansson ( )
Score
Tolga
43
Answered
Accepted Answer
Hi,
today I had the same issue with an iPhone 4S!
In my situation it was caused due to a bad quality of the replacement digitizer (incl. LCD). When I looked at the borders of the Digitizer, the left side of the black frame border was a little bit higher than the other side.
Due to this quality fault the LCD gets pressure from bottom and it causes white ghost effects on the outlines.
Will return it and order another one from another shop.
Good luck!
Best regards,
Tolga
0
Score
Adem
11
Answered
0
Score
Answered
0
Score
Marcos
Answered
I just replaced an lcd and after about 30 min it developed this halo. I haven't had a chance to fix it, but I think it was because I didn't remove the blue plastic film on the back of the lcd. Not having enough clearance, the plastic presses against the lcd and causes discoloration. Hopefully I can fix this issue tomorrow.
Hi Tolga, Many thanks for your answer. I think I have exactly the same issue as there's a gap between the frame and the screen on the left side on my phone too. will chase a refund. Daniel
Daniel Hansson,
I had this problem with a customer's iPhone 4s after I attempted to modify a CDMA screen to fit. I used a dremel to cut off one of the tin notches and I think the vibration from the dremel damaged the LCD. I did the same thing to yet another CDMA screen--so managed to trash two of these units, in the same day, with the same white halo effect. Needless to say, I no longer try to convert CDMA screens to fit 4S screens.
Chris Brehm,
