0
Score
Avatar
Kevin Rodger
Asked
Screen replacement causing problems
History
Hi,
I replaced the LCD on an A1181 macbook. To do this I released the hinge covers that allowed the screen and lid to pop out. I replaced the screen and tested it with no clutch cover on. New screen works a treat. When I put clutch cover back on and re-assembled the screen is blank. Without the clutch cover the screen works perfectly when re-assembled. Thoughts?
Kev
Edited by: oldturkey03 ( ) , machead3 ( )
Post Answer
Score
Avatar
machead3
69.3k
Answered
Accepted Answer
PermalinkHistory
I would go over all the cables with a magnifier to be certain there's no nick or cut that is shorting out against the frame. Tape down the ribbon connector securely so that you can rule out it's movement disconnecting it. Ensure there's no "torque" to the cables as you connect them to rule out that pressure breaking contact.
If this Answer is helpful please remember to return and mark it Accepted.
Add Your Answer
Today: 0
This Week: 0
This Month: 1
All Time: 266
