Model A1285 / 8 or 16 GB capacity
206 Questions View all
LCD is dark - plug in charger lights up for split second
Got a Nanon 4th generation, 8GB. The LCD is totally dim, did a factory reset ... weird thing is if I plug in the charging cable in from time to time it lights up fully for a split second then goes dim. But not all the time.
Guessed it might be just a loose lcd cable, but jiggled, tapped, etc, with no results or flicker.
Figure I will just order in a new lcd, but just wondering if someone has experienced the same issue (just kinda voodoo weird) out of curiosity.
Score 2
1 Comment
btw, tried different charging cables, same result, wanted to note that.
by
Add a comment
1 Answer
Chosen Solution
Country Computer Service, this model iPod has issues with corrosion on the logic board especially around the display connector. I would start by cleaning the logic board thouroughly and replacing the LCD.
Score 3
1 Comment:
Thanks, I'll do that.
by
Add a comment
Add your answer
Country Computer Service will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 677
