0
Score
Avatar
lab308joe
Asked
What Part Do I Change Once The iPhone 4s Gets Wet?
History
My phone decided to take a swim! yeah I know right? I've been letting it sit in rice for more than 24 hours it still hasn't turned back on, incase it doesn't after another 24 Hrs what can i replace to get it going again?
Edited by: machead3 and oldturkey03 ( )
Post Answer
5
Score
Avatar
rj713
39.6k
Answered
Accepted Answer
PermalinkHistory
Here is a link to the cell phone water damage guide. Its for 3G but most of the procedures should be the same. Good luck.
Repairing iPhone Liquid Damage
Cool I ordered the battery and tools to open it. Gonna see what damage was done. hopefully the rice got most of the moisture.
lab308joe,
4
Score
Avatar
Stefano Gigante
2.5k
Answered
PermalinkHistory
Well, you should never, ever try to turn on a water damaged device.
Water itself is not damaging, but it deroutes electricity where it's not supposed to do.
So, at first, you should dismantle your device and clean it throughly with isopropylic alchol. Let the parts dry, then reassemble and evaluate.
You're surely going to need a new battery: yours surely was shorted when it got wet.
After the battery change, you could check for other signs of damage.
Product Image
iPhone 4S Replacement Battery
Replace that dying battery or carry an extra for backup power! — 50+ available at 29.95 each.
Thanks I'm gonna give it a shot!
lab308joe,
Be careful. Keep every small piece handy. You may need the "iPhone Liberation Kit" to remove the pentalobes in the back.
Stefano Gigante,
0
Score
Avatar
dave77er
Answered
PermalinkHistory
The most common problem on the iphone 4S which has been exposed to water is battery failure. With the 3GS it is usually the LCD. Remember that the rice trick is only a temporary solution since moisture can still be trapped inside of the main board shielding. Read more about what to do with a wet cell phone here. As a previous poster said, turning the phone on is a bad idea as it causes electricity to flow through components that are still wet. This can easily short something out and cause more damage. Once you replace the battery pay attention to whether the phone gets hot while charging. This is a good sign that you will have problems in the future.
Add Your Answer
