0
Score
Avatar
gmac
11
Asked
purging hst trans. how to
History
hydrostatic trans is not working right. topped up fluid but now might need perge. model ys 4500
Edited by: gmac ( )
Post Answer
0
Score
Avatar
oldturkey03
88k
Answered
Accepted Answer
PermalinkHistory
gmac, this should work for your tranny :"
IMPORTANT: Should your transmission require removal for service or replacement, it should be purged after reinstallation before operating the tractor.
1. Place tractor safely on a level surface - that is clear of objects and open - with engine off and parking brake set.
2. Disengage transmission by placing freewheel control in disengaged position (See "TO TRANSPORT" in this section of manual).
3. Sitting in the tractor seat, start engine. After the engine is running, move throttle control to slow position. With motion control lever in neutral (N) position, slowly disengage clutch/brake ,_pedal.
CAUTION: At any time, during step 4, there may be movement of the drive wheels.
4. Move motion control lever to full forward position and hold for five (5) seconds. Move lever to full reverse position and hold for five (5) seconds. Repeat this procedure three (3) times.
5. Move motion control lever to neutral (N) position. Shutoff engine and set parking brake.
6. Engage transmission by placing freewheel control in engaged position (See "TO TRANSPORT" in this section of manual).
7. Sitting in the tractor seat, start engine. After the engine is running, move throttle control to half (1/2) speed.
With motion control lever in neutral (N) position, slowly disengage clutch/brake pedal.
8. Slowly move motion control lever forward, after the tractor moves approximately five (5) feet, slowly move motion control lever to reverse position. After the tractor moves approximately five
(5) feet return the motion control lever to the neutral (N) position. Repeat this procedure with the motion control lever three (3) times.
Your transmission is now purged and now ready for normal operation." from the owners manual. Hope this helps, good luck.
Add Your Answer
