screws that hold battery in
The ifixit installation manual shows two screws holding the iphone 4S battery: one, a 1.7 mm phillips screw, the other, a 1.5 mm phillips screw.
Nobody in town has phillips screwdriver bits to fit or precision driver kits, for that matter. Ifixit's "liberation kit" includes a pentalobe driver (which I now have) and another driver, a #00 Phillips head which is not otherwise specified as to bit size, but I wonder if it is supposed to fit both the 1.7 mm and 1.5 mm screws? What is the true bit specification for that seemingly "dual purpose" screwdriver?
I see the following declaration for the ifixdit #00 driver.
"Also indispensable for bridging the divide between squabbling materials, the screwdriver helps keep a healthy perspective on petty conflicts. Screw the differences today with our Phillips #00 screwdriver."
My impression is that the ifixit Phillips #00 screwdriver is meant to be used to replace the pentalobe screws with appropriate Phillips head screws...that it has nothing to do with the two different Phillips head screws that secure the battery inside the case.
Or, does the ifixit declaration mean an ifixit #00 phillips screwdriver will "bridge the divide" between 1.7 mm and an 1.5 mm screws and not strip their tiny little heads?
6 Comments
Nicholas, I "felt" the bit seat on the first screw and it turned out OK. I did not feel that seating / mating when I tried to unscrew the second screw.
After you last comment, I put more pressure on the driver and the screw did not turn. The bit is not biting. Have I done something wrong? Is there a backup plan?
by franklin6
No need to panic just yet. We just need to check on a few things first. Since I'm not sitting there with you with the device in front of me I need to be sure of what you are seeing. I have a theory but I need more information before we can act on it.
This is the fixture in question, correct?
http://guide-images.ifixit.net/igi/tAZJS...
The Orange circled screw is the 1.5 mm and the Red the 1.7 mm.
Can you verify for me that the screws are laid out and look exactly like this?
by Nicholas
Nicholas, here's what I see.
Yes, the screw that won't unscrew is circled in orange.
Furthermore, I looked around the case and found ten other phillips head screws, 6 with larger heads, 4 with smaller heads. The larger screw head slots (+) are more distinct; the smaller, less distinct. The orange circled screw looks like a small one, and it looked dfferent, perceptibly smaller, than the red circled screw that turned out easily under the #00 bit.
Now, after I tried to press the orange-circled screw to turn it out, the (+) looks more like this:
(o).
by franklin6
Really, it sounds to me like you had an irregular screw in the 1.5 mm slot. There is no reason why the #00 Phillips driver would not easily pull the 1.5 mm Phillips head screw. I'm sorry for your troubles. What seems most likely to me is that the 1.5 mm Phillips head that was meant to be in that slot was somehow replaced with a smaller 5-point pentalobe screw from somewhere else on the phone. Either that, or the screw itself was irregular and prevented the driver from setting properly. Sorry I couldn't be of more help, man.
by Nicholas
If you've managed to strip the head you either had a bad screwdriver or were being a bit dainty with it.
With a bit more force and a screwdriver with a bigger head you may be able to get it out still - would be good to see some pictures.
The 2 battery screws are standard - nothing a #00 screwdriver can't handle.
by ReekoB
Show 1 more comment
