Repair information and guides for the fifth generation of iPhone. Model: A1387
2193 Questions View all
iPhone 4 and 4s battery the same?
Can I use an iPhone 4 battery in an iPhone 4s ?
Thanks!
Score 16
4 Comments
can i use an i phone 4s battery on an iphone 4
by
Can I use a 4g battery in a 4 s
by
can i use iphone 4s battery for iphone 4
by
Yes you can use it..but fix the connecter in opposite side...I am using...
by
Add a comment
Chosen Solution
Unfortunately the simple answer is no. The iPhones 4's battery has a different voltage and the connector is slightly different. If you need a new battery you can get one from here,
iPhone 4S Battery
that will work no problem in your phone.
Hope this helps.
iPhone 4S Battery Image
Product
iPhone 4S Battery
$16.99
Score 13
4 Comments:
voltage is the same at 3.7. 4s batt has tiny more watt hrs. make it fit by modify connector tab only.
by
by
The voltage is the same. They are both 3.7 volt batteries. However the 4s battery has a very slightly higher capacity.
by
Owen Cunneely youre wrong sir
by
Add a comment
Batteries are different physical size as well. The 4 is bigger than the 4s. Normally the 4s will fit in the 4, but not vice-versa.
Score 3
3 Comments:
Very helpful ta very much. Ytnir.
by
if i need a battery for an iphone 4, will the 4s battery work?
by
I think the 4S fits in the 4, yes, but this is a terribly late answer to your question :-)
by
Add a comment
2 Comments:
by
if voltage is the same can you switch between the batteries?
by
Add a comment
Add your answer
Ricky will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 55
All Time: 148,566
