0
Score
Avatar
sayhiworld
Asked
No Signal after battery replacement (iPhone 3GS)
History
I have opened my 3GS to replace battery and did reassembly after battery replacement. I am getting Wi-Fi but not the carrier signal. From the articles here, I found that I did something wrong when I removed "Do not Remove" label.
Can anyone help in fixing my issue>
Thanks in advance for your help and advice.
Post Answer
0
Score
Avatar
Gido Nijenhuis
527
Answered
PermalinkHistory
First you best check the nr 7 connector. It is located in the bottom right of the logic board. This is the antenna for the cellular (carrier signal) network. It can sometimes be very difficult to properly mount this connector.
If you are certain this connector is seated ok please make a picture of the logic board around this nr 7 connector. Maybe you have chipped something off the logic board.
0
Score
Avatar
sayhiworld
Answered
PermalinkHistory
Thanks for the prompt response. I have connected Connector 7 properly. Please check my main board pic in the link here,
http://www.flickr.com/photos/79479917@N0...
Thanks for the picture. I do think to see something unusual around the antenna part. Can you take a closer picture of the bottom right corner as I can not clearly see it on this picture.
Gido Nijenhuis,
Have anyone fixed this issue before? Please let me know the solution if you have fixed already.
sayhiworld,
Add Your Answer
