Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2396 Questions View all
does not charge anymore..
I have tried to open my phone and when I disconnected the battery cable a something went wrong there and it does not charge anymore. It turns on if I connect it, but it does not charge, even if it looks like is charging.. How much would it cost to repair it?
Score 1
2 Comments
have you damaged the phone in trying to open it? Have you checked the battery connector is intact etc? If you have damage please post a photo.
by
I ve uploaded 2 photos.. is damaged :( but it still works very good, the problem is that is not charging anymore, even though it looks like is charging
by
Add a comment
1 Answer
Chosen Solution
Try to restore the phone. It will probably do nothing, but it could fix the problem. The one thing you should do is let it do a backup first, to be sure the phone is backed up. If that doesn't help replace the battery in the phone. You can find the guide here and the battery here.
Depending on the tools you have, there's a chance you could strip the Pentalobe screws on the phone. These screws are easy enough to strip, replacement may be needed. The screws can be found in the parts section of this guide. As of recent times, you may no longer need screws to deal with the damage. You can find Pentalobe drivers as standalone items, or in the driver bit kits. But if you lose or strip them you will need the replacement set.
iPhone 4 Battery Image
Product
iPhone 4 Battery
$11.99
Guide
iPhone 4 Battery Replacement
Difficulty:
Moderate
5 - 30 minutes
iPhone 4 Pentalobe Screws Image
Guide
iPhone 4 Pentalobe Screws Replacement
Difficulty:
Easy
1 minute
Score 3
Add a comment
Add your answer
Meano will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 8,538
