Guides and repair information for washing machines produced by Maytag, a subsidiary of Whirlpool.
323 Questions View all
My MVWB766FW1 will not start. Outlet is fine and no error code show.
We tried reset and does not make any difference. Power from outlet is fine. No error code appears and no green light. Nothing to indicate what is the trouble. What to do next?
Add a comment
1 Answer
Most Helpful Answer
Hi @barbarajen99312,
Here's the tech sheet for the washer that may help.
Go to p.2 and check if the diagnostic LED on the control board is On or Off.
If it is Off follow the directions to check if the voltage supplies are OK or not.
If it is ON, try to run the diagnostic tests as described by the manual also on p.2
If there's a faulty part that needs replacing here's the parts list that is useful.
Search through the list to find the wanted part and when you find it you'll see that the manufacturer's part number for the part is listed with it.
Search online for the part number only to find suppliers that suit you best.
Score 1
Add a comment
Add your answer
Barbara Jensen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 10
