Repair guides and support for your LG TV.
1355 Questions View all
Does not turn on and the backlight is flashing
@oldturkey03 this is LG65UN7200, this one has exactly the issue "Won’t turn on and back light flashing" as roger phillips' one. I changed Power supply board by a new board but it is still being the symptom, still not turn on and back light flashes. One more thing, when I unplug the power cable of the back light led -> the stand-by light goes ON, but when plugs it in, the stand-by light not ON
Score 1
Add a comment
1 Answer
Most Helpful Answer
@tom99704 this "when I unplug the power cable of the back light led -> the stand-by light goes ON, but when plugs it in, the stand-by light not ON" would lead me to the backlights. If you have a multimetre, check the voltages on the backlight connector. Measure that with and without them being connected.
It appears as if there is a failed backlight strip, which could cause behaviors like the one you described. Replacing the strips is a bit of a PITA with a panel size as big as your TV but it's definitely doable. Check something like this guide LG 55UH6150 backlight LED replacement on how to do it. Different model same idea.
Score 1
2 Comments:
@oldturkey03 Thanks bro for your useful help. I changed the backlight strip -> It works.
Thank you so much again!
by
@tom99704 you are welcome and I am glad you got it working again. I like it when we can help people save their devices and save all of our hard earned money.
Repair is War on Entropy!!
by
Add a comment
Add your answer
Tom will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 30
