Released September 20, Apple's mainstream 2019 iPhone comes with a 6.1" LCD touchscreen, dual cameras, and six available colors. Successor to the iPhone XR.
481 Questions View all
iPhone 11 Reboots Panic log
"panicString": "panic(cpu 0 caller Oxfffffff01f8c85a4): userspace watchdog timeout: no successful checkins from thermalmonitord (2 induced crashes) \nservice returned not alive with context: is_alive_func returned unhealthy: current 3bfffffffffff, mask iffffffffffff, expected 1ffffffffffff. SD: 1 BC: 1 RC: -1 BS: 1, Missing sensor(s): mic2 \nservice: backboardd, total successful checkins in 197 seconds: 18, last successful checkin: 0 seconds ago\nservice: SpringBoard, total successful checkins in 169 seconds: 17, last successful checkin: 0 seconds ago\nservice: mediaserverd, total successful checkins in 197 seconds: 18, last successful checkin: 0 seconds ago\nservice: audiomxd, total successful checkins in 197 seconds: 18, last successful checkin: 0 seconds ago\nservice: logd, total successful checkins in 197 seconds: 19, last successful checkin: 0 seconds ago\nservice: thermalmonitord (2 induced crashes), no successful chooking in
Add a comment
1 Answer
Most Helpful Answer
This is a rather common issue in the iPhone 11 specifically. There is an entire page dedicated to these sort of kernel panics, but I'll cut to the chase.
Your iPhone is expecting a check in from a sensor and because it's not getting the expected data, it reboots. The sesnor referenced in your log is "mic2" which is the rear microphone. In the iPhone 11 this can be found on the power button flex cable. This cable also contains the camera flash.
It's best to replace this with an authentic Apple cable (there are places that sell cables pulled from good phones), or part from a reputable seller. There are many of these parts on the market that will continue to produce this issue, even after they are replaced.
Score 2
Add a comment
Add your answer
Jrf89 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 22
All Time: 51
