Repair and disassembly information for the first generation of Apple's high-end wireless earbuds. Released in October 2019. Identified by model numbers A2084 (left earbud), A2083 (right earbud), and A2190 (charging case).
67 Questions View all
Buzz sound on the left airpods pro while use both airpods
I'm having this issue (buzzing sounds only on the left side airpods) while use both airpods pro, but when I'm remove the right airpods the buzzing sound is gone. I 've tried bring to apple authorized service center but rejected. is there's any way to fix it? thanks
1 Comment
after turn off the noise cancellation the buzz sound on left airpods has gone, but when turn on to transparancy or noise cancellation the buzz sound came back again
by
Add a comment
Most Helpful Answer
In this case, I think your headset has Active Noise Cancellation function error. Apple has a service program. The program covers affected AirPods Pro for 3 years after the first retail sale of the unit.. I have covered a few cases same issue. Good luck.
https://support.apple.com/service-progra...
Score 1
1 Comment:
hi thanks for your input, i try this before but end up declined by apple authorized service center
by
Add a comment
This same thing happened to mine. A loud static sound when in noise cancellation or transparency mode, making them unusable in those modes. Unfortunately, it seems to be a common issue but might have to do with dirt in the airpods disrupting the microphones used for those modes.
I'd suggest trying to clean them with compressed air.
1 Comment:
cleaning the microphone at the end of the stem or microphone inside the earpiece? since compressed air will makes the dust or dirt pushed deeper and deeper, should I vacuum the dirt?
by
Add a comment
Add your answer
geronimo will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 7
Past 30 Days: 22
All Time: 52
