A series of 15.4" Toshiba laptop in the Satellite line.
3 Questions View all
Distorted Audio in laptop speakers and headphones
The Audio on my Toshiba Satellite Pro is frequently distorted in applications like spotify and itunes and on the web. it happens with any audio that is being played. majority of the time it's fine however it goes distorted occasionally is this a driver problem or a hardware problem? (I am running Windows XP Home Edition SP3)
Add a comment
1 Answer
Not having much detail and assuming both channels are distorting, I can venture the following:
Audio distortion can be due to a number of factors
  1. Turning up the volume to a point where the load (speakers/headphones) can't handle the power can cause AF clipping (distortion).
  2. The built-in amp is being overdriven IOW not enough power to handle the volume
  3. The built-in laptop audio amplifier has a component (such as a Capacitor for example) that is intermittent and will cause distortion under certain conditions (overdriving, overheating, Age)
  4. So, this sounds more like a HW problem. I am assuming the laptop is a number of years old and was acquired when XP was still the go-to opsys
  5. A common way to test (if you are able to get at the laptop's innards) is to induce or wait until distortion occurs and then apply a freeze-it spray to where you suspect the AF amp and components to be. This most likely will be an IC but with larger output capacitors usually mounted as discreet components on the pc-board itself. If the distortion dissapear you may have fingered the culprit.
Add a comment
Add your answer
Lewis Johnston will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 13
All Time: 23
