Repair guides and support for your Samsung TV.
2636 Questions View all
Samsung Samsung qled showing double image all the time (QA55Q70TAKXXL)
Samsung QLED 55 inch Q70T (QA55Q70TAKXXL)
This TV was bought around Dec 2020 in India.
Double imaging started showing a few seconds and now it's showing all the time
I attached the required images.
I also reviewed other threads regarding this. Should I change T Con board if yes, please tell me where should I buy it.
I also saw this fix in the youtube
https://youtu.be/XwG7t1FEhh0?feature=sha...
Can I try this?
Add a comment
1 Answer
@sara10012 the video is referring to a Tape-off. Sure you can try it and it may resolve the issue, if it is related to a bad panel. It will not resolve it if it is a bad board. Once you have the back cover off your TV, take some good pictures of all of your boards and post these with your Question. That way we can see what you see. Adding images to an existing question
Add a comment
Add your answer
Sara will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 9
All Time: 23
