Repair guides and support for riding, or ride-on, mowers, also known as lawn tractors, of all types used in tending large tracts of land.
860 Questions View all
Mower makes awful noise when I take foot off brake
The last time I went to use my mower everything started out fine. I had started riding and cutting with it, no worries. Then, I noticed I big tree branch in my path, so I disengaged the blade and locked in the clutch brake. When I returned, I took off the brake-lock and took my foot off the brake. Next thing I know, I'm hearing this awful grinding noise that only stops when I press down on the brake. Even the slightest touch on the brake will stop the noise.
I was wondering if this means that the clutch belt has been over stretched or if there is some other reason why this is happening.
Thank you for taking the time to review my request,
Help Plz
1 Comment:
This question was migrated from https://meta.ifixit.com/Answers.
by
Add a comment
1 Answer
When you press the clutch/brake pedal, the first thing that happens is the drive is disengages.
So, you are stopping the tractor drive but not applying the brakes, right.
If so, it should make the same noise with or without the blades engaged.
If that is true, you might have debrie around the drive train.
If it doesn't drive, maybe a bad drive belt.
Add a comment
Add your answer
xvlsex will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 27
All Time: 48
