A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
170 Questions View all
How do I mount more HDDs on my old gaming PC?
Hi all,
Not too long ago, I decommissioned a PC I built in 2021. It had an Rtx 3080 TI (currently not in the system as I'm reusing it in a custom cooling loop), an AMD Ryzen 9 5900x cooled by an h150i elite cappelix (might consider replacing it), 32GB of DDR4 3600MHZ vengeance RAM, A 970 evo plus, and an ASUS Crosshair VIII Hero (AM4). This is all in a Corsair 5000x case btw. I plan to Reuse this as a homelabs-style plex server to host games on or a NAS. My main problem is that I want to mount more than 2 HDDs on this thing, would that be possible? If not, what are some other ways I can add some more storage for this thing?
Score 1
Add a comment
Chosen Solution
@arandomhitman why not just run en external HDD enclosure. You can get those for 4 and more and it allows you to use a variety of drives etc. They have their own power supply, some are even hot-swappable and you can get those for relatively little money. Something like this (example only) seems to provide plenty of storage possibilities without to much fuss
Score 2
2 Comments:
I'd prefer to get stuff internally so I wouldn't have a mess outside, but fair enough. I'll consider it, thank you for your time and answer.
by
@arandomhitman I agree. Keeping it all in one case keeps it neat and tidy. Only issue is it'll get heavy, crowded and awfully hot since it'll be using a lot of power :-) Remember those old tower cases with 4 5.25 bays? There was enough room in those to fit at least 6 drives but they were the size of a NY apartment.
by
Add a comment
Hey there,
Adding two more HHDs to your machine should be easy enough. Based on what I found on your specific case, there should be enough room to add either 2 x 3.5" storage drives, or 4 x 2.5" drives. The only thing that you are going to want to double-check is that your power supply has enough power.
Best of luck to you
Score 1
6 Comments:
Thanks for the answer,
Would it be possible for me to mount more HDDS somewhere? I know it's an unconventional move, but Id rather not switch cases. If not I'd just settle for a couple of 870 evo SATA SSDS.
by
@arandomhitman Yes, the case you listed in your specs should have a bay for internal HHDs.
by
Let me rephrase that: Would it be possible to mount MORE than two HDDs in the 5000x? I know it's unconventional, but I want to know if it's possible at all.
by
@arandomhitman Oh, I gotcha. Yes, it is possible as long as the HHDs are 2.5" drives.
by
I do apologize, im a bit new to the whole drive sizing scheme. Would I be able to mount 4 WD purple HDDS? if not that's fine, as ill go with 3 870 evo SATA SSDS and a couple of old barracuda HDDS I have.
by
Show 1 more comment
Add a comment
Add your answer
ArandomHitman will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 11
All Time: 66
