The Nintendo Switch is a handheld game console that can be played on the TV via a docking station, or on the go. Released March 3rd, 2017.
709 Questions View all
Why wont my switch turn on after water damage and I tried fixing it
Nintendo switch fan comes on when I connect the battery to the motherboard but it doesn't show anything on the screen and I tried it with a dock and nothing happened.
Add a comment
1 Answer
If your Switch is refusing to boot due to corrosion, then I believe that the motherboard is broken (along with some other components within the Switch). Sure the fan may come on, but that doesn't mean that some other component of the motherboard is still broken. So I would suggest a motherboard replacement, a guide on which can be found here (unless you can clean it somehow, which I talk about below): Nintendo Switch Motherboard Replacement
Other components of the Nintendo Switch may have also been damaged, such as the display or some other daughterboards (e.g. the MicroSD card reader), so I would recommend checking them for any corrosion, which can be cleaned up using this guide: How to Correctly clean corrosion from a MacBook Pro logic board. (I know it is for a MacBook and not a switch, but the processes are basically the same for the Switch)
If you are unable to clean up the corrosion, you can simply purchase replacement parts here: Nintendo Game Console Parts
Do note that this sort of repair may be rather costly and take a lot of time, so if you do wish to carry out this I do wish you the best of luck with it.
MacBook Pro Image
Guide
Difficulty:
Moderate
2 hours
Nintendo Switch Motherboard Image
Guide
Difficulty:
Moderate
1 - 2 hours
Add a comment
Add your answer
Julian Valentine will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 15
All Time: 43
