Released September 20, Apple's mainstream 2019 iPhone comes with a 6.1" LCD touchscreen, dual cameras, and six available colors. Successor to the iPhone XR.
482 Questions View all
iPhone 11 mute switch not working
Hi
I had a cracked iphone 11 and the frame got bent a lot. I ordered a new back housing. I took all the parts from the broken iphone to the new casing except the mute&volume flex since it got ripped when the iphone broke. So I ordered a new flex and installed it on the new back housing. I put on the mute button under the springs. For some reason the mute switch does not work. The volume buttons work perfectly. I dont understand why since mute switch and volume buttons are connected on the same flex. I tried to check the ribbon that goes from the mute switch if it has any damage but I dont see anything wrong. Can it be the button itself is not seated correctly under the springs?
Add a comment
1 Answer
I have not before replaced the mute switch, but if it seems to function correctly, when installing, then maybe its a faulty flex. First thing is to try another cable.
Add a comment
Add your answer
Besbes will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 17
All Time: 48
