2nd-generation magnetic AC power adapter for MacBook products, first released in 2012. Not compatible with previous generation systems. Available in 45W, 60W, and 85W versions.
26 Questions View all
Brand new Magsafe2 charger LED light leaking from cable, is it faulty?
This a brand new adapter from Apple store, there's a green light leakage from the cable at the magsafe 2 head, is this normal or it's faulty?
It's from UAE apple store and a friend got me the adapter sealed to Egypt so I can't go to apple store right away and replace it unless the friend take it again to UAE.
Sorry for being paranoid, I had terrible stories with repair shops in Egypt which ruined and burnt my previous adapter.
P.S. why not buying from Egypt? No apple stores and it costs 3x its price. I added the Other picture because someone told me on other forum it's scratched not brand new while it was only a residue from the plastic wrap! So it's the same but with flash and the leak is barely visible.
Thank you
Score 1
Add a comment
Most Helpful Answer
Mine has been the same way ever since I first unboxed it. I bought it directly from Apple.com so it isn’t counterfeit. Not sure if it is a common defect/issue or what but mine has been working fine for years without issue. I wouldn’t worry too much about it unless further issues arise if I were you.
Score 3
1 Comment:
Thank you so much for your help and assurance. I think it's common to an extent, just looked at old replacement adapter I got from a repair shop and thought it was shady, has the same bleeding but a little bit less on one side than my new one.
by
Add a comment
Mine is fine and I have a 2021 16" (MagSafe 3), just a little leaky. My cable also came from Apple, and I had to supply my own USB-C adapter and cable, so I think it's to a degree, expected.
Score 2
2 Comments:
Thank you so much for your help and assurance, I guess it's a common thing then but varies to several extents.
by
@jaimed3437 If the charger works, it's an issue you live with. Seems like most cables have a bit of leakage.
by
Add a comment
Add your answer
JaimeD will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 100
