Repair guides and support for motherboards and CPUs.
166 Questions View all
Replace LAN port on Dell E5550 laptop motherboard
Hi All, this is more of a search question. I have a Dell E5550 laptop. The LAN port, which is integrated into the motherboard, is worn out and I want to replace it. I know I can replace it, but I cannot find the part. Does anyone have any links or insight into where I can find this part. There is a number on it of S5267. Tried to search it and came up empty. Thanks in advance
Add a comment
1 Answer
Hi @sthomaschllc
Here's an image of the LAN port from the schematic for the motherboard that may help.
The LAN port part number is Santa130456-511 but I had no joy when searching for it but I found this when searching for a 13 pin RJ45 socket which may be suitable.
Here's the owner manual for the laptop. Go to p.37 to view the procedure to remove/replace the systemboard, which you most probably will have to do when removing/replacing the port.
(click on image)
Add a comment
Add your answer
Scott Thomas will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 7
All Time: 28
