Repair and installation information for light bulbs and fixtures.
153 Questions View all
antimosquitoes g23 bulb/lamp
I have an antimosquitoes lamp (from aldi or lidl), bulb form is G23 but i don't have enough info from bulb or the lamp.
I understand light type has to be Actinic/BL as it is the one used to attract mosquitoes.
And in the lamp i can measure a power around 90V.
Most g23 bulbs on internet doesnt have specs about its power/current. Why?
What type of lamp should i buy?
Score 1
Add a comment
1 Answer
Most Helpful Answer
@alcrepaircafe I am probably misunderstanding your Question here but anyway. Here are the measurements for the G23 light base
110V or 220V starter and capacitor inside for the G23 base. Since you measured a lamp voltage of 90V you could check the rest of the electrical values on here
At 90V it should be an 11W bulb.
Hope this is at least slightly helpful
Score 2
2 Comments:
i had some mistakes on questions, i just edited it ;)
Yes it must be 11W as per consumption at label.
So the same lamp can work on other voltages and therefore different Watios?
by
@alcrepaircafe that looks about right.
by
Add a comment
Add your answer
AlcRepairCafe will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 9
All Time: 30
